i have one but i want 800 for it.has 119k but it has a .756 tdi 5th.the rivets in the diff were replaced with apr?bolts and it had a reverse idler gear and syncro replaced.all done by ngp.got reciepts and has a lifetime warranty.0 miles since work was done.only thing wrong with it is the casing has a light bit of corrosion because i had painted it then when the work was done the case was cleaned so it ate some of the paint and the car sat outside in my driveway so moisture got to it so it would need a good sanding then repaint...it has motul gear oil in it.you may need to ad a tiny bit as when i went to move the trans some leaked out of the speed sensor hole when i had it upside down
