VWVortex.com - What to datalog to troubleshoot spark getting cut.
    Results 1 to 13 of 13
    Thread: What to datalog to troubleshoot spark getting cut.
    1. 07-31-2012 04:55 PM #1
      Hi folks,
      I'm troubleshooting an issue where my MK3 gti vr6 is cutting spark on the rear 3 plugs between about 1800-4000 RPM. The car isn't throwing codes, other than sai and evap on occasion. I want to track/log through the ECU to see what the injectors, as well as ignition is seeing. Can someone point me in the right direction on which banks to log?
      I've replace a ton of parts, but to no avail.
    2. 08-01-2012 02:31 AM #2
      Start with a complete auto scan of your vehicle using a current, licensed version of VCDS. Please read "Read This Before Posting...." sticky in this forum.
    3. 08-01-2012 03:18 AM #3
      Sure. Here it is:
      VCDS Version: Release 10.6.4
      Data version: 20110418
      Canadubs Inc.
      Wednesday,01,August,2012,01:08:21:63905
      Chassis Type: 1H - VW Golf/Vento III
      Scan: 01 02 03 08 12 15 25 41 56
      Address 01: Engine Labels: 021-906-259-AAA.lbl
      Part No: 021 906 259 N
      Component: MOTRONIC M5.9 HS V03
      Coding: 00000
      Shop #: WSC 00066
      VCID: 205579408A53
      No fault code found.
      Readiness: 0110 1101
      Address 03: ABS Brakes Labels: 3A0-907-379.lbl
      Part No: 3A0 907 379 E
      Component: ABS/EDS ITTAE 20 GI V00
      Coding: 03704
      Shop #: WSC 00000
      VCID: 2C4D9D70F69B
      4 Faults Found:
      00285 - ABS Wheel Speed Sensor; Front Right (G45)
      35-00 - -
      00290 - ABS Wheel Speed Sensor; Rear Left (G46)
      35-00 - -
      16-10 - Signal Outside Specifications - Intermittent
      00287 - ABS Wheel Speed Sensor; Rear Right (G44)
      35-10 - - - Intermittent
      Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
      Part No: 1J0 909 603 T
      Component: AIRBAG VW3 - V04
      Coding: 00084
      Shop #: WSC 00066
      VCID: 3A61AB280CCF
      End ---------------------------------------------------------------------
      Through all this troubleshooting, we've replaced a ton of stuff. Tested a few coilpacks, but the rear 3 cylinders are not firing (or not getting enough current) pretty much from 1800 RPM+
    4. 08-01-2012 11:25 AM #4
      Sorry no help for old unsupported versions sir.
      Please upgrade and start over.
      http://www.ross-tech.com/vcds/download/
    5. 08-11-2012 09:08 PM #5
      OK. Done.
      VCDS Version: Release 11.11.3
      Data version: 20120401
      Canadubs Inc.
      Saturday,11,August,2012,19:07:36:63905
      Coding: 00000
      Shop #: WSC 00066
      VCID: 20557940A0D8C29
      3 Faults Found:
      16795 - Secondary Air Injection System
      P0411 - 35-00 - Incorrect Flow Detected
      17881 - EVAP Leak Detection Pump
      P1473 - 35-10 - Open Circuit - Intermittent
      17883 - EVAP Leak Detection Pump
      P1475 - 35-00 - Malfunction / No Signal
      Readiness: 0110 0101
      Coding: 03704
      Shop #: WSC 00000
      VCID: 2C4D9D70DC10169
      4 Faults Found:
      35-00 - -
      35-00 - -
      Coding: 00084
      Shop #: WSC 00066
      VCID: 3A61AB282644B89
    6. 08-11-2012 09:29 PM #6
      THIS POST MOVED/VACATED BY JACK TO PROTECT CONTENT FALLING INTO THE GAPING HOLE OF THE VORTEX
      IT SEEMS NO GOOD DEED GOES UNPUNISHED!
      http://www.youtube.com/watch?v=HaoySOGlZ_U
    7. 08-11-2012 09:38 PM #7
      I actually have that info handy. All that is new (chains, lifters, tensioners, guides). The engine was a complete rebuild, save for the valves themselves and the valve springs. Cam gear is OK.
      The guy who built the engine had a look at it last week and took the valve cover off to doublecheck the chains and timing were OK. Leakdown is OK. Timing is on. He did a leakdown a couple times on it. Came out OK.
      Could you explain what having some bent valves in the rear bank would cause spark to cut over 1800? Is it the cam position sensor? The crank position sensor is new too.
      Oh, on the valves themselves, they were re-lapped when the engine was reassembled.
    8. 08-13-2012 11:14 PM #8
      Also, from a data logging perspective, is there a way I can use my VAG-Com to compare the "signal/response" to the coilpack and compare the front and back banks? This would be to verify the ECU and ICM are "sending" properly.
      Let me know,
      Thanks,
    9. 08-14-2012 03:46 PM #9
    10. 08-14-2012 05:50 PM #10
      The loss of spark was tested with an ignition spark tester. There's spark up until 1800, then there is none, but only on the back.
      My understanding of the coilpack is that we should probably see failures of only 2 plugs, as they're paired on the coilpack itself. Edit: I read up on wasted spark, so my understanding of how this one works seems to have been accurate, I was just lacking the association to the term, "wasted spark".
      We've double-checked cam timing as well. It's correct. The guy I'm working with has been a VW/German mechanic for the better part of a decade and he's even a bit perplexed. That's why I turned here. If educating myself about this is the resolution, then can you please point me in the direction of some literature and I'll stop asking for help here, or at least be able to ask this question more intelligently.
      As for plug wires, I've had 3 sets of plug wires on there, 2 coilpacks, and replaced the following parts:
      MAF
      Blue coolant sensor
      low oil pressure sender
      Crank position sensor
      I'm sure I've missed some other parts. I've been having this issue for almost two years now, so if you're saying there's nothing I can look at from a VAG-Com perspective to help me with this, then I'll move along, other than to ask if there's a way to check for the oil pressure issue you've mentioned.
    11. 08-14-2012 06:18 PM #11
    12. 08-16-2012 02:48 PM #12
      No, sorry I'm not in NY. I'll have to doublecheck on where all my parts came from. I'm just going to go through all the checks again and document them as I go along. I'll for sure swap the plug wires to test it out. I'm also going to pull the plugs (again) to make sure they're not fouled or otherwise messed up.
      Thanks for the help. I'll post up what I find. It's going to take a bit of time to gather the results though.
    13. 09-24-2012 12:06 PM #13
      Back from the dead. I tested the coil with an inline ignition tester. Getting spark on all plugs, even into high revs. Must have been something wrong with the other test.
      I'm going to upgrade the grounds and check the compression just to be sure. I thought I heard valve slap, but it came and went, so I have to assume that was the lifters having drained (really hoping actually).
    « Back
