Results 1 to 6 of 6
Thread: Redirecting Cabi Fuel Lines: Questions
  1. Member HareRocket's Avatar
    Nov 28th, 2005
    Portland, Oregon USA
    84 rabbit gti
    07-31-2012 08:09 PM #1
    So, I am doing my 2nd 16v swap. First was into a a2 gti, and the other was in my 84 rabbit. Both times Fuel lines were on the passenger side of car so access to FPR was direct and easy. With the Cabi I face another scenario: End of fuel lines on Driver side of car. So my question is what is the best way to go about this swap so I don't waist time and money. Can I just extend the line to the FRR with extra fuel tubing or will that extra tubing effect the fuel pressure in the system? Also, should I just keep the Fuel filter on the drivers side where it currently is? Any qualified help appreciated. thanks guys
    I have a1/a2 vw parts for sale
  2. Member HareRocket's Avatar
    Nov 28th, 2005
    84 rabbit gti
    07-31-2012 08:11 PM #2
    Also, Can I keep my existing Cabriolet Fuel Pump or will an upgrade be needed? thanks
    Past swaps I just used the existing 1.8l 8v fuel pump in the car.
  3. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    '86 Cabriolet G60, '82 280ZX Turbo, '06 325i Problem Child
    07-31-2012 08:41 PM #3
    Stock pump is fine so long as your FPR is up to snuff. Some say the 80psi will kill digi FPRs quicker than normal, no problems with me so far.
    Gently bend your existing fuel lines over to the passenger side, cut to length and flare. Then just use standard 8mm fuel hose.
    Edit: Stick whatever fuel filter you want in line. I'm using an $8 fram fuel filter from Wal-Mart.
    It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark... and we're wearing sunglasses.
    -Hit it.
    RooflessVW
  4. Member waterwagon's Avatar
    Apr 7th, 2002
    Hampton Township, NJ
    '08 GTI '93 Cabriolet '89 Jetta
    08-01-2012 08:25 AM #4
    You made no mention of the year of the Cabriolet; that matters. The fuel pumps are diffrent from CIS to DIGI cars and DIGI fuel pum will not provide enough fuel pressure for the 16v. I know this first hand from a past swap.
    As for the fuel lines; that has been covered. They run up the passenger side of the car then make a turn at the firewall to det to the drivers side. Bend and cut, done.
  5. Member HareRocket's Avatar
    Nov 28th, 2005
    84 rabbit gti
    08-05-2012 02:21 AM #5
    Quote Originally Posted by waterwagon View Post
    Oh yea sorry, forgot to mention it is a 1985 CIS. nice, so i can use it then?
  6. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    08-05-2012 05:45 AM #6
    Quote Originally Posted by HareRocket View Post
    Runs my G60 with 68mm pulley just fine. 16v should be no problem. There is talk that the high pressure CIS pump can kill FPRs fast, but I've had no problems yet at about 17,000kms since the swap.
    -Hit it.
    RooflessVW
