VWVortex.com - Beetle Conv still dying
    Results 1 to 12 of 12
    Thread: Beetle Conv still dying
    1. 07-31-2012 10:40 PM #1
      Car will run fine and then just die. Wait a few minutes and it will start back up and run again without issues. Never know when it will die or when it will start either. Tried starting it earlier in the driveway and it would just crank. A few minutes later started without any issue.
      Have replaced the battery, crankshaft sensor and ignition switch and still having issues. Here is the latest Vag-Comm. I cleared all the codes but still have 2 ABS codes that will not clear. Did the Select Control Module and cleared them in the ABS module but they still remain.
      Looking for any ideas as I am about to give up on this car.
      Tks
      Tuesday,31,July,2012,18:30:49:13996
      VCDS Version: Release 11.11.3 (x64)
      Data version: 20120401
      Chassis Type: 1Y - VW New Beetle Cab
      Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
      VIN: 3VWFG31Y37M421596 Mileage: 18830km/11700miles
      Address 01: Engine Labels: None
      Part No SW: 07K 906 032 AA HW: 07K 906 032 AA
      Component: NB R5 AT G 9654
      Revision: --H01--- Serial number: VWZ5Z0G5047178
      Coding: 0000003
      Shop #: WSC 00066 000 00000
      VCID: 68DF03C05B68FA9
      2 Faults Found:
      000768 - Random/Multiple Cylinder Misfire Detected
      P0300 - 008 - - Intermittent
      Freeze Frame:
      Fault Status: 00101000
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 18824 km
      Time Indication: 0
      Freeze Frame:
      RPM: 802 /min
      Load: 55.7 %
      Speed: 3.0 km/h
      Temperature: 33.0°C
      Temperature: 32.0°C
      Absolute Pres.: 1000.0 mbar
      Voltage: 14.097 V
      000772 - Cylinder 4
      P0304 - 008 - Misfire Detected - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 18824 km
      Time Indication: 0
      Freeze Frame:
      RPM: 722 /min
      Load: 37.2 %
      Speed: 13.0 km/h
      Temperature: 42.0°C
      Temperature: 32.0°C
      Voltage: 13.970 V
      Readiness: 0010 1101
      Address 02: Auto Trans Labels: 09G-927-750.lbl
      Part No SW: 09G 927 750 FM HW: 09G 927 750 FM
      Component: AQ 250 6F 0921
      Revision: 00H66000 Serial number:
      Coding: 0000008
      Shop #: WSC 00000 000 00000
      VCID: 8109BE64DB12AB1
      2 Faults Found:
      01314 - Engine Control Module
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 12
      Reset counter: 40
      Mileage: 18486 km
      Time Indication: 0
      008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 12
      Reset counter: 40
      Mileage: 18486 km
      Time Indication: 0
      Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
      Part No: 1C0 907 379 Q
      Component: ESP FRONT MK60 0101
      Coding: 0019978
      VCID: 387F93804848AA9
      4 Faults Found:
      00778 - Steering Angle Sensor (G85)
      014 - Defective - Intermittent
      003 - Mechanical Failure
      005 - No or Incorrect Basic Setting / Adaptation
      Address 15: Airbags Labels: 1T0-909-605.lbl
      Part No: 6Q0 909 605 AL
      Component: 01 AIRBAG VW71 0811
      Coding: 0012337
      VCID: 8109BE64DC12AB1
      Component: BF-Gewichtsens.
      No fault code found.
      Address 17: Instruments Labels: None
      Part No: 1C0 920 803 E
      Component: KOMBI+WEGFAHRS. M73 V01
      Coding: 11234
      Shop #: WSC 00066
      VCID: 1F4D581C9DA6FD1
      1 Fault Found:
      49-10 - No Communications - Intermittent
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN V012
      Coding: 00006
      Shop #: WSC 00066
      VCID: F0EFEBA0B0B8B29
      1 Fault Found:
      Address 25: Immobilizer Labels: 1C0-920-xxx-25.clb
      Part No SW: 1C0 920 803 E HW: 1C0 920 803 E
      Component: IMMO X007
      Revision: xxxxxxxx Serial number: VWZ5Z0G5047178
      Shop #: WSC 131071 1023 2097151
      VCID: 1F4D581CCDA6FD1
      Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
      Part No: 1Y0 959 255 C
      Component: VSG NBC 3601
      VCID: 408FFB601098E29
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 G
      Component: 6J Komfortgerát HLO 0004
      Coding: 00256
      Shop #: WSC 00066
      VCID: 3B758C8C297E811
      Subsystem 1 - Part No: 1Y1959801C
      Component: 6J Tőrsteuer.FS KLO 0005
      Subsystem 2 - Part No: 1Y1959802D
      Component: 6J Tőrsteuer.BF KLO 0005
      Subsystem 3 - Part No: 1Y0959811
      Component: 6J Tőrsteuer.HL KLO 0005
      Subsystem 4 - Part No: 1Y0959812
      Component: 6J Tőrsteuer.HR KLO 0005
      2 Faults Found:
      00932 - Electric Window Motor; Drivers Side (V147)
      62-00 - No or Incorrect Adjustment
      00933 - Electric Window Motor; Passenger Side (V14
      Address 56: Radio Labels: 1J0-035-18x-56.lbl
      Part No: 1C0 035 196 CT
      Component: RADIO DE2 0006
      Coding: 06033
      Shop #: WSC 22820
      VCID: 73E564AC41AE091
      End
      2007 Beetle Triple White Convertible Auto Trans 2.5L engine BPR 013513
    2. 07-31-2012 11:27 PM #2
      Update:
      Daughter took the car out and got to her destination. Came back out and it would not start, waited 5 minutes and it started. I really wish I had a clue.
    3. Member vwbugstuff's Avatar
      Mar 27th, 2004
      NW Chicago 'Burbs
      2012 CC "R"-Line, 2003 Eurovan, 1979 Westfalia, 1978 Superbeetle Convertible, 1998 New Beetle
      08-02-2012 12:45 AM #3
      Random misfires sometimes indicate a faulty ignition coil. That could cause random dying and a "crank-but-no-start" situation (especially if the engine is hot).
      Good luck!!!
    4. 08-03-2012 12:59 AM #4
      Went over a lot of the detail with a different mechanic today and we zeroed in on the cyl 4 misfire. Started moving the wires going into the coil pack and got the car to die. Did this 6 times in a row. Reseated the coil pack connection and no more dying when you move the wires.
      CEL light was on at one point but it went back out at some point so I find that very strange.
      Started the car several times after re-seating the coil connector and had no issues.
      Had it started and we were standing there discussing the car and it just died. No warning, nothing, just died. Started right back up without issue.
      So we have found one issue but there is something still going on. Will clear all the codes in the morning and start over.
    5. Junior Member
      Jun 21st, 2012
      Philadelphia
      2000 VW Beetle GLS 2.0L, 1996 Nissan Maxima GLX
      08-03-2012 09:51 AM #5
      Keep us updated!
      Let us know your progress, it helps other users to solve similar issues.
      Does the car act up when it's about to shutdown it self?
      Try clearing out the MAF sensor. Some times you don't any codes for dirty MAF sensor.
      Engine getting fuel correctly?
      -Maybe need a new fuel filter
      -Fuel pump needs to be checked.
      Edit:
      Oh cell(battery) light was on? Might be some electrical problem.
      Check your alternator by starting the car and taking out the negative terminal from the battery and see if the car stalls or dies. If it dies/stalls then it means your alternator is going bad.
      Good luck.
      novice in car repair; learning everyday by experiencing and researching.
    6. Junior Member
      Jun 21st, 2012
      Philadelphia
      08-03-2012 10:41 AM #6
      LOL try this...
      If you cant start the car, try opening the driver side door for 2-5 seconds then closing it and start the car!
      I just read that "When the door is opened the fuel pump is activated for 2 seconds to build up pressure in the fuel system."
      ABS
      Not sure about that, mine switched on when i put my car on the jack stands for couple of days and brought the car down.
      Maybe wires on the sensor got stretched out and broke or connection got loosen off.
      If i find a fix i'll let you know.
    7. 08-04-2012 05:30 PM #7
      Back to square one. Put in a new coil on cyl 4 and no change. Car will be running at idle and just die. Not starving for fuel die, but just die. Most of the time it starts right back up. Codes, codes and more codes. Maybe it is time for a new wiring harness. Extended warranty will kick in soon so then I don't care if the dealer replaces everything under the hood. Just don't know if I can wait the next two weeks for the repair.
      I read on another post where someone basically set their ECM back to default and it had to relearn everything and that solved his problem. It wasn't a Beetle but a Golf or something else and pretty much had the same symtoms as mine. Something like changing the coding back to 0000001 on everything. Don't know how to do that or if I would want to try, mess up my ECM and I am really screwed.
    8. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      08-04-2012 06:58 PM #8
      Have you looked into the steering angle sensor code? Not sure what all that sensor can affect...
      You also are getting ECU codes.
      If you haven't, I'd try clearing the codes and see what pops up when you start the car again. Also, if you are getting more codes than the ones posted, post those as well.
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
    9. 08-06-2012 06:24 PM #9
      Here is the log from the ABS module:
      Monday,06,August,2012,11:57:48:13996
      Address 03: ABS Brakes (1C0 907 379 Q)
      11:57:43 Group 001: Current Wheel Speed
      0.0 km/h Speed Sensor Front Left (G47)
      0.0 km/h Speed Sensor Front Right (G45)
      0.0 km/h Speed Sensor Rear Left (G46)
      0.0 km/h Speed Sensor Rear Right (G44)
      11:57:43 Group 002: Starting Wheel Speed
      255.0 km/h Speed Sensor Front Left (G47)
      255.0 km/h Speed Sensor Front Right (G45)
      255.0 km/h Speed Sensor Rear Left (G46)
      255.0 km/h Speed Sensor Rear Right (G44)
      11:57:43 Group 004: Steering Angle / Lateral Acceleration / Rotation Rate
      731.98° Steering Angle Sensor (G85)
      0.00 m/s^2 Lateral Acceleration
      0.00°/s Rotation Rate
      N/A
      Drove the car around the block and the Steering Angle Sensor went up to 1050 and locked there. Stopped the car and turned it off. Restarted it and it was back at 0, as soon as I turned the wheel it went back into the 700's as shown in the log.
    10. 08-06-2012 06:27 PM #10
      Here is the log from this morning:
      Friday,03,August,2012,09:05:40:13996
      VIN: 3VWFG31Y37M421596 Mileage: 18850km/11712miles
      Coding: 0000003
      4 Faults Found:
      005668 - MIL Request Signal Active (Check TCM for errors too!)
      P1624 - 008 - - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 3
      Mileage: 18842 km
      Time Indication: 0
      Freeze Frame:
      RPM: 737 /min
      Load: 29.8 %
      Speed: 0.0 km/h
      Temperature: 76.0°C
      Temperature: 46.0°C
      Voltage: 12.700 V
      004964 - Cylinder 4 Ignition Circuit
      P1364 - 004 - Open Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 0
      Fault Frequency: 3
      Mileage: 18858 km
      Time Indication: 0
      Freeze Frame:
      RPM: 671 /min
      Load: 45.9 %
      Speed: 0.0 km/h
      Temperature: 84.0°C
      Temperature: 47.0°C
      Absolute Pres.: 990.0 mbar
      Voltage: 12.954 V
      P0300 - 001 - - Intermittent
      Freeze Frame:
      Fault Status: 00100001
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 18858 km
      Time Indication: 0
      Freeze Frame:
      RPM: 626 /min
      Load: 43.5 %
      Speed: 0.0 km/h
      Temperature: 87.0°C
      Temperature: 47.0°C
      Voltage: 13.208 V
      000772 - Cylinder 4
      P0304 - 001 - Misfire Detected - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 18858 km
      Time Indication: 0
      Freeze Frame:
      RPM: 626 /min
      Load: 43.5 %
      Speed: 0.0 km/h
      Temperature: 87.0°C
      Temperature: 47.0°C
      Voltage: 13.208 V
      Readiness: 0010 1000
      Coding: 0000008
      2 Faults Found:
      Freeze Frame:
      Fault Status: 10101000
      Fault Priority: 2
      Fault Frequency: 13
      Reset counter: 44
      Mileage: 18486 km
      Time Indication: 0
      008 - Implausible Signal - MIL ON
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 13
      Reset counter: 44
      Mileage: 18486 km
      Time Indication: 0
      Coding: 0019978
      4 Faults Found:
      003 - Mechanical Failure - Intermittent
      Coding: 0012337
      Coding: 11234
      Shop #: WSC 00066
      1 Fault Found:
      Coding: 00006
      Shop #: WSC 00066
      1 Fault Found:
      Coding: 00256
      Shop #: WSC 00066
      Coding: 06033
      Shop #: WSC 22820
      End ---------------------------------------------------------------------
      Monday,06,August,2012,11:29:26:13996
      Coding: 0000003
      Coding: 0000008
      2 Faults Found:
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 15
      Reset counter: 40
      Mileage: 18486 km
      Time Indication: 0
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 15
      Reset counter: 40
      Mileage: 18486 km
      Time Indication: 0
      Coding: 0019978
      3 Faults Found:
      Coding: 0012337
      Coding: 11234
      Shop #: WSC 00066
      1 Fault Found:
      Coding: 00006
      Shop #: WSC 00066
      1 Fault Found:
      Coding: 00256
      Shop #: WSC 00066
      Coding: 06033
      Shop #: WSC 22820
    11. 08-23-2012 08:53 PM #11
      Any resolution? Found your thread after posting mine:
      http://forums.vwvortex.com/showthrea...History-Advice
      Seems like it could be relevant. Thanks!
    12. 08-31-2012 10:13 PM #12
      Thought we were finally on to something as it wouldn't start for two days straight. Towed it in and as soon as they were going to push it into the shop they tried and it started. Has started everytime since. Codes beyond codes but they don't lead to any known issues. Still a shot in the dark. I am just about to put a new wiring harness in it and see what happens. Extended warranty has kicked in so I really don't care what they do now. They can replace everything from the bumber back and it will cost me $100 now.
      With an issue like this it is a complete shot in the dark. Bad wire somewhere I am betting but finding it will be a nightmare.
