Results 1 to 4 of 4
Thread: Is my strut mount blown?
  1. Member Turbo-D's Avatar
    Jan 28th, 2003
    Portland, OR
    92 16v, 95 M3
    07-31-2012 11:07 PM #1
    This is a oem g60 strut mount and bearings seem fine and all the rubber is in great shape. it seems that the mount doesn't fit into the shock and I do have a noise coming from the car when i go the full lock or if I hit a bump mid turn sometimes. I have the tool and i can not get the nut any tighter and according to the bentley its put together right.
    Any ideas?
  2. 08-18-2012 04:18 PM #2
    Bump
    Jan 4th, 2007
    MA
    2004 Jetta GLS 1.8T
    08-30-2012 03:19 PM #3
    Maybe it wasn't installed properly or correctly. it should not have that kind of movement.
    Quote Originally Posted by Turbo-D View Post
    Any ideas?
  4. Member
    Mar 23rd, 2008
    N/A
    N/A
    08-31-2012 10:23 PM #4
    The strut mount looks too close to the upper spring perch to me.
    Are you sure you have all of the right parts assembled on the strut shaft?
    Did you forget the lower collar nut, or is the strut mount collapsed?
