Results 1 to 6 of 6
Thread: Door Lock/Vaccum line problems
  1. Junior Member
    Apr 11th, 2008
    Appleton, WI
    97' VW Jetta
    07-31-2012 11:22 PM #1
    I recently had my car painted and after we put the interior back together, i tried locking the doors...
    the drivers side door goes down, and you can hear the motor in the trunk running when you do it, but no other locks go down, i ahve to manually push/pull them to lock/unlock them, where do i start? are there diagrams of the vaccum lines? someone help, id like my locks to work like normal lol
  2. Junior Member
    Oct 31st, 2009
    Halifax, NS - Canada
    1999.5 mk3 Golf 2.0l 8v
    08-01-2012 12:52 PM #2
    Some of this you may already know, so I won't pretend to know everything:
    Connecting the doors to the body of the car are large black "accordion" cords/ hose, that, if you unscrew them you'll see they contain a number of electrical and other connections (power windows, locks, etc) to the doors. They do have notches in them that I suppose you could unscrew with some massive wrench, but you should be able to unscrew them just with your hands.
    Inside of that big tube will have be a small 1/8" hose. This is your power lock vacuum hose that runs from the main pump near your right tail light. If any one of those hoses is not connected properly, (at any of the door connections) the vacuum won't be strong enough to pull all of the locks down.
    Sometimes when screwing on those big electrical connections (accordion hose) the power lock vacuum lines don't reconnect well.
    With the door still on the car, propped open as wide as possible, unscrew that large black "accordion hose" on the car body end. Check to see that the vacuum line (it should be orange or blue and plastic / vinyl) is connected well to the plug on the body of the car. You can actually pull the vacuum line away from the door connection and make sure it's jammed into the opposing connection before screwing on the larger connection (accordion hose) that it is held within.
    I hope that my explanation was somewhat understandable.
  3. Junior Member
    Apr 11th, 2008
    Appleton, WI
    97' VW Jetta
    08-01-2012 11:41 PM #3
    awesome info, i appreciate it... any other opinions are welcome..
  4. Junior Member
    Apr 11th, 2008
    Appleton, WI
    97' VW Jetta
    08-08-2012 12:42 AM #4
    bump
  5. Junior Member
    Apr 11th, 2008
    Appleton, WI
    97' VW Jetta
    08-13-2012 12:42 AM #5
    bump
  6. Member insanedubposse's Avatar
    Mar 18th, 2005
    middletown ny
    91gti,99 wolfsburg jetta(mk3)
    08-25-2012 05:43 PM #6
    does the pump run for a long time..cause my buddy had a golf somebody stripped down and we put the interior back in .he dropped the rear bench while doing it and cracked the plastic line running side to side under the carpet just behind the seat,but you could hear an air leak
    currently-91 monty green gti (16v)-vr6..,99 t-red wolfsburg jetta aba..---- in the past-85 goldy golf gl cis,89 silver jetta gli 16v,88 t-red wolfsburg jetta digi 2,97 white golf k2 aba,91 t-red corrado g60--
