Results 1 to 4 of 4
Thread: OIL LEAK HELP!! 2001 audi S4
  1. 08-01-2012 02:35 AM #1
    im leaking some oil from inbetween the engine and trans at the bottom of the car. only a few drops over night. where is it coming from if anyone has had a similar problem?! thanks!
  2. Junior Member
    Jun 12th, 2010
    CT
    08-01-2012 04:38 PM #2
    Could be your Rear main seal behind your clutch.
    2.7T 2001.5 A6 RS6-R's, Aquamist HFS 6, VAST LWFW, CM FX500 Soon 500+whp
    2.7T 2000 A6 Frankenturbos FX 400
    2.7T 2000 B5 S4 (currently parts car)
  3. Junior Member
    Aug 4th, 2012
    Boston, MA
    '13 VW Golf R
    08-04-2012 11:43 PM #3
    Check the valve cover gaskets, cam seals and cam plugs. All three are known to leak.
  4. Member
    Jun 20th, 2010
    Danbury, CT
    Bagged/Shaved/Stanced DBP .:R :: 2001.5 Audi S4 ::
    08-12-2012 11:53 PM #4
    Quote Originally Posted by robopp View Post
    cam seals would be in the front of the motor, cam plugs could be a possibility but (drivers side) would land on the manifold and burn off as he drove therefore it would smoke and (passenger side) would also be smoking. I dont think thats it but definitely check all of those they are very common to leak and cause future problems as well as the valve cover gaskets
