Results 1 to 18 of 18
Thread: Msd Standalone questions??? Help
    Mar 13th, 2011
    Mertztown PA
    97 golf gl, 95 vr6 passat wagon, 85 chevy, 78 blazer, 89 iroc, 84 s10, 99 gti
    08-01-2012 05:59 PM #1
    Hi, so i recently purchased a msd 6al2 box the msd blaster 2 coil pack, and a msd distributor that i though was for my aba 2.0 but when it arrived i found out that it is for a air cooled. So now im stuck wondering how im going to be able to make a standalone for my 2.0. i will be running itbs,and i want to completely get rid of my ecu and all the wiring that goes alone with it, im comming for v8 chevys. please help. Is there a known distributor out there that will work with my sytem or will i beable to mod a 1.8 distributor.?
    VRalliance#169
  2. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    08-02-2012 05:42 AM #2
    Quote Originally Posted by k2rider5936 View Post
    Bahn Brenner sells an adapter that allows a 1.8l distributor to be used on an ABA. But it would be easier in the long run to get an Electromotive XDI and run it with the factory ABA crank sensor.
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 08:34 PM #3
    If you have an ABA id recommend using the built in 60-2 wheel on crank and research a standalone system. Some to consider are Megasquirt or Lugtronic. Explore the different options, support, price, etc.
  4. Member
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 09:06 PM #4
    some one told me that i wont need to swap the distributor, im putting a fuel cell and a external pump in the car, so i dont need the ecu to trigger that, and the car has a button start , so what would be stoping my from ditching it all together??
    VRalliance#169
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 09:08 PM #5
    Are you running carbs or fuel injected Itbs?
  6. Member
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 09:33 PM #6
    i dont belive that they are fuel injected itbs.
    VRalliance#169
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 09:34 PM #7
    they are the obx itbs for a crossflow 8v, i havent gotten them from the mail yet.
    VRalliance#169
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 09:42 PM #8
    The obx Itbs are definitely fuel injected. You need a full standalone.
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 09:51 PM #9
    I just relised that they were fuel injected itbs, well they wont be going on till winter when i build up the motor, it looks like im going to need alot of supporting mods for them to run properly, do you know anyone who dose make a decent standalone?
    VRalliance#169
  10. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 09:57 PM #10
    i personally run Lugtronic with my ITBs. They offer plug and play setups, custom harnesses, and DIY wiring. Also includes support and a base map based on your specs and can exchange data logs to make adjustments to maps. This is the 4th or 5th ITB setup we have done with Lugtronic.
  11. Member
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 10:02 PM #11
    Is there no way to run these itbs on my stock engine managment?
    VRalliance#169
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 10:06 PM #12
    If you can rig up an air box for the maf. It'll still prob run like dog****. I worked on an aba ITB in a rabbit and the motor is mostly stock with a cam and little higher compression. Super fun car.
  13. Member
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 10:08 PM #13
    i definatly think it will be. Personaly id like to ditch the whole harness, the custom harnnes that they show dose it come with all the plugs?or do i have to do a lot of cutting and splicing?
    VRalliance#169
  14. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 10:10 PM #14
    It depends on what car it is going into. If it is ce2 90- it will plug in. No splicing. If before that you may need to connect 4-5 wires. All new connectors, wire, heatshrink.
  15. Member
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 10:10 PM #15
    its in a 97 golf.
    VRalliance#169
  16. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 10:14 PM #16
    You can get plug and play adapter harness to use with stock harness or full custom harness that will just plug right in.
  17. Member
    Mar 13th, 2011
    Mertztown PA
    08-02-2012 10:15 PM #17
    Will this system allow me to use my msd stuff as well??
    VRalliance#169
  18. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    08-02-2012 10:21 PM #18
    None of it is needed.
