Hi, so i recently purchased a msd 6al2 box the msd blaster 2 coil pack, and a msd distributor that i though was for my aba 2.0 but when it arrived i found out that it is for a air cooled. So now im stuck wondering how im going to be able to make a standalone for my 2.0. i will be running itbs,and i want to completely get rid of my ecu and all the wiring that goes alone with it, im comming for v8 chevys. please help. Is there a known distributor out there that will work with my sytem or will i beable to mod a 1.8 distributor.?
VRalliance#169
The Professor
Melbourne, FL
M & L EFI Performance
If you have an ABA id recommend using the built in 60-2 wheel on crank and research a standalone system. Some to consider are Megasquirt or Lugtronic. Explore the different options, support, price, etc.
some one told me that i wont need to swap the distributor, im putting a fuel cell and a external pump in the car, so i dont need the ecu to trigger that, and the car has a button start , so what would be stoping my from ditching it all together??
VRalliance#169
Are you running carbs or fuel injected Itbs?
they are the obx itbs for a crossflow 8v, i havent gotten them from the mail yet.
VRalliance#169
The obx Itbs are definitely fuel injected. You need a full standalone.
I just relised that they were fuel injected itbs, well they wont be going on till winter when i build up the motor, it looks like im going to need alot of supporting mods for them to run properly, do you know anyone who dose make a decent standalone?
VRalliance#169
i personally run Lugtronic with my ITBs. They offer plug and play setups, custom harnesses, and DIY wiring. Also includes support and a base map based on your specs and can exchange data logs to make adjustments to maps. This is the 4th or 5th ITB setup we have done with Lugtronic.
#11
Is there no way to run these itbs on my stock engine managment?
VRalliance#169
#12
If you can rig up an air box for the maf. It'll still prob run like dog****. I worked on an aba ITB in a rabbit and the motor is mostly stock with a cam and little higher compression. Super fun car.
#13
i definatly think it will be. Personaly id like to ditch the whole harness, the custom harnnes that they show dose it come with all the plugs?or do i have to do a lot of cutting and splicing?
VRalliance#169
#14
It depends on what car it is going into. If it is ce2 90- it will plug in. No splicing. If before that you may need to connect 4-5 wires. All new connectors, wire, heatshrink.
#16
You can get plug and play adapter harness to use with stock harness or full custom harness that will just plug right in.
#18
None of it is needed.
