Yes but those fine soft touch dash materials.
#1
So today was my first day of summer vacation, I got my garage prepped for the upcoming TT timing belt and Forester head gasket cluster****fest. No prob, have a new compressor, air ratchet, and put an AC window unit in so I don't pass out while working on the crap. All in all, I was pretty excited about taking care of things. But today I also got a report, my Mom's 2007 535xi started having troubles, and it conveniently just went out of warranty (like 3k ago). She calls me and tells me her rad fan sounds like a jet, and I confirm overheating through the dash message. After researching the past 2 hours, I've settled on the fact that she will need a new waterpump and thermostat.
Bend over! The two parts are going to cost over $500Not only that, BMWs are known for having **** waterpumps and thermostats, and apparently this is a typical maintenance interval for the two **** parts. I have to DIY it because with labor it'd cost over a grand, and there is NO WHERE to get the parts for cheaper. Really BMW? Goddamn it, the price is outrageous, electric pump or no. 50k lifespan for a basic pump and thermostat? Yea I shouldn't be surprised at the price because its electric, and the fact is its a BMW, but all the same it pisses me off because these kinds of parts should last. Yet another thing on the summer to-do list, and her 535 has had a litany of problems/recalls already (apparently the e60 is known for being a ****storm of problems).
I'm going to fix it, but I'm sick of ANY car having issues with such basic parts. Cars have needed both parts essentially since they were invented, can't someone just figure out a way to design basic stuff so they don't suck ass?! Its a ****ing waterpump and thermostat, figure them out already! Stop designing parts around warranty schedules you ****ing idiots![]()
#3
Edit- misread your price estimate.
Yea BMW rubber and plastic never lasts. It's to be expected unfortunately.
You can save a little money here:
http://www.turnermotorsport.com/p-16...-e60-535i.aspx
#4
Yup. I'm sorry to say it, but nothing new here. BMW's waterpumps and thermostats have sucked as long as I can remember.
Of course, I've had BMWs for so long that I don't even know what a typical lifespan is for these parts. How long do these items tend to last on Hondas? Full lifespan of the car, I'd imagine.
Anyway, irritating. I feel your pain. Good luck.
DD: 2012 GLI
Gone but not forgotten: 2010 Golf 2.5
Summer fun: 1995 M3
Former E36 318i driver and self-appointed Chairman of the Momentum Preservation Society.
#5
Someone needs to make a belt-driven conversion for that car.
A water pump *should* last 100k miles.
It's more like it than it was before.
#6
#7
Look at your signature, now back to mine, now back to yours, now back to mine. Sadly, yours isn’t mine.
#8
These electrical pumps are nonsense. Thanks god, industry don't follow BMW in their craziness, all of this to save maybe 1-2HP.
2007 N52N were repackaged and don't seem to suffer this issue like the 2006 325i/330i N52 had. I have heard of maybe 1 328i with this issue but tons of 335i with it. The N54 is unfortunately very affected and additional heat may be a reason.
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
#11
Water pump - $249:
http://www.ebay.com/itm/2008-2012-BM...761#vi-content
Thermostat - $76.99
http://www.fcpeuro.com/products/bmw-...at-11537549476
You're welcome![]()
#13
Yea yea yea I know
But their package deals are usually good. When I had my e36, I got the OEM Euro clear tail lights for like 250 for both of them from them which is quite a bit less than retail. I think an E36 cooling system rebuild kit is like 400 from them.
I wouldnt go used on something like this considering how short the life span is to start with. Do they make aftermarket ones though? There are some companies that make WPs for the E36 that cost a bit more but last the lifetime of the car, so that offsets the purchase price.
#14
Yup. Sounds about right. I'm just waiting for mine to go.![]()
"She's workin' at the pyramid tonight..."
'08 BMW 335i Sedan
#15
http://www.rockauto.com/catalog/raframecatalog.php
The thermostat is $74.79
I like rock auto they have some pretty good prices
#16
What will really burn you up is that the ECU has actually been aware of the water pump failing for a while. It throws plausibility codes that are shadow codes which don't activate the CEL but can be seen with the proper cable. It isn't until the thing actually totally fails that it kicks the fans into high gear and goes into limp mode. Also, the control electronics on the pump are what fail, the actual motor and impeller are fine 98% of the time.
Finally, there is a new part number that supposedly rectifies the issue and should last. Do some more searching before you buy the part.
2010 GMG GT-R, 10.72 @ 132 so far / 09 E92 335i M-tech, JB4 and E85 mix
Past: 300 hp A4, 500 hp Evo, 430 hp 335, and a 520hp Z06
#17
#18
Fukin BMW Water Pumps..
How Do They Work?
#20
#21
With working with BMW for over 10 years now, all I can do is...
If you knew e60's/BMW's in general had **** cooling systems and other things, what kind of input did you give for her even buying the car? Why are you complaining about the price? Shouldn't mom be worried about that?
And why are you blaming BMW for not being able to get the parts elsewhere? Not their fault an aftermarket company hasn't designed a better replacement part that has been around for over 6 years now...
I will laugh even more if it turns out not even being the problem...
Best of luck!
Current: 2005 Subaru Legacy GT Wagon Limited 5MT
Past: 2004 BMW 330i ZHP - 2002.5 VW Passat GLX Wagon - 2007 BMW 335i Coupe 6MT - 1991 BMW 325ix Coupe - 2003 VW Jetta 1.8t
#22
#23
did not read, but there are aftermarket water pumps with metal blades that last longer.
#24
More Money, more problems
BMWs are know for their pathetic plastic cooling components.
#25
she bought euro instead of japanese, what did ya'll expect
lol
why can't they have good quality engineered parts ?
having good suspension doesn't mean squat, when you're taking a turn, a part breaks and you crash
#26
#27
Waw, I can usually get things pretty cheap, so I checked and these water pumps are darn expensive!
#28
On older Hondas with timing belts you typically changed the water pump every 60-100k miles (depends on model year) "while you were in there" doing the t-belt since it was only an extra $40 or so for the part. There's no maintenance interval on the newer ones with chains, and I just searched for "k-series water pump failed" and the first page of Google results was all for Rover K-series engines, not Honda ones.![]()
Improving the signal-to-noise ratio
#29
Geez, I didn't know BMW attitude came from the service people as well, thanks!
She bought it new, before anyone had really had problems (read: before anyone knew to stay the **** away). I'm worried about the price cause its an utter ripoff, and why should I hope an aftermarket company rectifies the situation? How about BMW, with their amazing reputation and engineering prowess, design a WP that doesn't fail? The car has more electronics than NASA but the basic parts are ****. Skip fancy and build something without taking leasing percentage into consideration...and don't get me started on how there isn't a goddamn dipstick...![]()
#30
When RX8s (or other more affordable vehicles) have issues- that shows they are junk.
But when BMWs have issues- that is just the price of owning such an amazing vehicle, and complaining just exposed you to not be proper BMW owner material.
And on topic- if this really is a known part issue, I am surprised somebody hasn't stepped up to offer a better part (heck- even Mazda changed to better replacement parts to address part issues just a few years after the 04 RX8s went on sale).
#31
So OP, you're complaing your mother has to replace the water pump on a 5 year old car just because she bought it new?
5 years is pretty aceptable for a cooling system refresh......
#32
Hmm, I think not. Lets see:
* Electric pumps can be turned on or off by the ECU depending on the cooling needs. The BMW electric pump operates in conjunction with the cooling fan. If the temperatures start rising, the fan operates at a higher speed and the water pump enters "Component Protection Mode" which helps cool down the engine quickly.
* When the engine is cold, the coolant does not circulate. This helps decrease warm up time, which in turn improves fuel efficiency, decreases emissions and allows the passenger compartment to be heated quicker.
* The ECU can choose to shut down the coolant pump when it is not needed, thus eliminating a large portion of the parasitic drag of a conventional belt driven unit. This further improves efficiency of the engine.
* The ECU can turn on the coolant pump even when the engine is not running. This allows for the turbos to cool off quickly and it eliminates the need of a turbo timer for these cars.
* The ECU can turn on the coolant pump and provide heat to the passenger cabin when the car is parked and the engine is warm but shut off.
* The ECU can dial in the precise temperature it wants the engine to operate in. If more power is needed, then the ECU will increase the cooling capacity because lower temps make more power. If the ECU aims for fuel efficiency (which it does on highway) it will increase the engine temperature because high engine temps provide better fuel economy.
Frankly, I see no reason why one would ever want a belt-driven coolant pump anymore.
Now, concerning the OP's mother's BMW, I am willing to bet my lunch for an entire week that the car has automatic gearbox. Unfortunately, BMW in their infinite wisdom, have decided to cool the automatic transmissions via the engine coolant. So the cooling system in those cars with automatic transmissions have to work overtime not only because the twin turbos (which are water cooled and oil cooled) are dumping so much heat, but also because the automatic transmission is also dumping a lot of heat.
There are lots of 335i cars out there with over 100K miles and the original coolant pump. The vast majority of those however are cars with manual transmissions which require no cooling.
EDIT: I forgot to mention that having an electric pump controlled by the ECU allows for some interesting tuning solutions. Almost all of the N54/N55 engine tuners offer some sort of improved logic for cooling the engine. Even BMW themselves have a different cooling algorithms in the software for the Performance Power Kit in the 335is and 1M
#33
No, the time isn't a big deal, and even the mileage is "acceptable" I guess, its that the bitch costs almost $500. If anyone has to pay that much for a simple waterpump it should last far longer than 50k. I'm not BMW owner material, even my TT is basically cheap, most of the parts from a Golf/Jetta can be used and its been extremely reliable - hell, my coilpacks have 85k on them, and its only after 120k that I really need to install a new clutch. The Bimmer has had 4x as many issues in under half the mileage
And, yes, its an auto...
#34
#35
Im gonna agree right here. You really have no reason to speak this way either because you own an audi TT. Waterpumps and timing belts are every 60k miles on the 1.8t. How is that any better than this BMW?
And are you absolutely sure that it is the pump itself that has failed? Being an electric pump that leaves many other possibilities to cause lack of operation besides the unit itself.
