VWVortex.com - R32 swap in corrado g60
    Results 1 to 12 of 12
    Thread: R32 swap in corrado g60
    1. Member One_Off_Volk's Avatar
      Nov 30th, 2011
      L-Town, NH
      mk6 jetta, 1992 corrado r32 (in progress)
      08-01-2012 11:30 PM #1
      What do I need to do the swap? I have a g60 corrado and a spare r32 motor and oem 6 speed tranny along with the ecu and all the wiring. How can I do it? Do I need to get custom axles, mounts, subframe?
      I've searched high and low for a thread on r32 motors in g60's and haven't found much and was looking for some help.
      It's a g60 and I'm planning on keeping it fwd for now, is there any major differences between the 24v swap in a g60 compared to the slc?
      Should I keep the oem 6 speed tranny or get an o2m tranny for the swap? Which would be easier with the lesser amount of custom work?
      Thanks
    2. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      1992 Corrado ABA-T and MS3-Pro powered, 84 Honda V65 Sabre
      08-02-2012 12:10 PM #2
      you'll need SLC front and rear subframes to start
      The Professor
      Melbourne, FL
      92 Corrado OBD2 ABA-T (BW EFR 6258) Powered by MS3Pro
      Linfert Performance: The Megasquirt guy in central Florida Like my Facebook page....
      Sandy Linfert 11/4/1991 - 5/13/2013
    3. Member Gaets's Avatar
      Feb 7th, 2005
      Easton, Maryland
      1991 GTI 24v, 1997 Golf GLX, 2002 Golf GLS
      08-02-2012 12:46 PM #3
      To start you will need a vr6 subframe like stated above. The simplest way of mounting the engine is to use an o2a transmission and axles. If not you have to make a custom trans mount and custom length axles. Use a 12v rear engine mount bracket as well as the front engine mount/bracket (whatever you want to call it) and everything bolts into place just like a 12v vr6 does. On the front mount/bracket you need to use a spacer on one of the bolts because the 24v blocks are missing one of the bosses that the 12v's have. If you search 24v swap you will find most of this information. As far as the wiring goes, I ended up going with standalone on my 24v swap. It made everything much easier than splicing harnesses together and getting the ecu immobilizer defeated. PM me if you have any specific questions, Ill try and help best I can.
    4. Member
      Nov 1st, 2009
      Phenix City, AL
      1983 Rabbit GTI 16v turbo Haldex swap Texas Mile project.
      08-03-2012 08:58 AM #4
      The 6sp trans is an O2M. If you go with the 6sp, you can get the brackets from dutchbuild or from a guy on here. I dont remember his name right now. You have to move the trans mount cup back roughly a 1/2" to clear the bigger axles. You also have to get custom length axles which can be made for about $400 if you use the stock cv's.
      My 16v turbo Haldex rabbit and my quest for 200 at the Texas Mile build
      http://forums.vwvortex.com/showthrea...8#post90875298
    5. Member One_Off_Volk's Avatar
      Nov 30th, 2011
      L-Town, NH
      08-03-2012 09:32 PM #5
      Where can I get custom axles built?
      How would I get them built? Would I hav to have the transmission /motor in for them to custom make them?
    6. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      08-03-2012 11:18 PM #6
      Driveshaftshop has them available.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
      Nov 1st, 2009
      Phenix City, AL
      08-04-2012 01:01 AM #7
      Quote Originally Posted by StayFatlaceMK3 View Post
      There are a few places that can build them for you. In order to get an accurate measurement for the axle length you need the trans in the car and it sitting at ride height.
    8. Member One_Off_Volk's Avatar
      Nov 30th, 2011
      L-Town, NH
      08-04-2012 01:07 AM #8
      Quote Originally Posted by need_a_VR6 View Post
      That's just what I was looking for! Thanks!
    9. Member vwmaniac16vr6's Avatar
      Nov 17th, 2004
      North-west NJ 07838
      08-13-2012 02:15 PM #9
      I can offer an immo defeat and convert the wire harness so it is plug n play into the ce2 fuse box. Also if you get a passat vr6 cluster it will be fully functional. I can also offer recoding of the ecu to eliminate can-bus communication code for abs, air bag and gauge cluster. So im or call me if your interested.
    10. Member PinoyVR6's Avatar
      May 23rd, 2003
      Norwalk, CT
      90 Nugget Yellow Corrado, 2003 Jetta W>E
      08-26-2012 05:44 PM #10
      I'm thinking about doing the same thing but have a functioning AC and power steering
    11. Member One_Off_Volk's Avatar
      Nov 30th, 2011
      L-Town, NH
      08-26-2012 06:50 PM #11
      Quote Originally Posted by PinoyVR6 View Post
      What difference does that make?
      Nov 9th, 2009
      Miami,FL
      mk2 24V VR6
      08-26-2012 09:36 PM #12
      Quote Originally Posted by vwmaniac16vr6 View Post
      clear inbox
