Results 1 to 6 of 6
Thread: newbie here with a mkII question
  1. 08-02-2012 01:57 AM #1
    I've recently bought an 88 golf 8v and its turning out to be more of a project than I thought so this is probably the first of many questions I'll have for you, world. Question being: when starting my car i need to give it gas in order for it to start and then need to keep giving it gas for a few seconds til it calms down and decides it can run on its own. What is causing it to do this and how would I go about fixing it?
  2. Member boostedbastid's Avatar
    Aug 31st, 2009
    portland oregon
    w124 300E 3.2L 24v
    08-02-2012 12:28 PM #2
    start with a tune up, seafoam, and clean throttle body/intake then report back
    DubSaints Alpine White supremacist
  3. Member bugflucker's Avatar
    May 11th, 2010
    oregon
    08-02-2012 06:53 PM #3
    Probably buy a Bentley if you haven't yet
    It's well worth it
    84 Jetta 2Door Daily driver
    81 Jetta 4Door diesel Daily driver - sold 9/2011
  4. Member rabbitinfife's Avatar
    Dec 22nd, 2007
    Fife,Wa
    A bunch of rusty Kraut cans
    08-02-2012 08:17 PM #4
    check for vacumn issues leaks.
  5. Member brad131a4's Avatar
    May 21st, 2003
    Sammamish
    01 S8 11 Golf TDI 77 rabbit in pieces behind garage.
    08-03-2012 11:41 AM #5
    Same problem with my 85 gti. One of 2 things or both are possible on this would be the cold start injector and the cold start thermol time switch. Both are fairly easy to diagnose and easy to fix but can be costly for such a simple little part.
  6. Member scirocconaut's Avatar
    Oct 7th, 2011
    Dallas/pdx
    1979 16v mk1 scirocco S model black with roof rack and no sunroof :)
    08-04-2012 07:36 AM #6
    Definitely vacuum leak,
    While your at it change your grounds
