VWVortex.com - OFFICIAL Beetle window issue thread
    Page 4 of 24 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 596
    Thread: OFFICIAL Beetle window issue thread
      Sep 27th, 2011
      Brooklyn, N.Y.
      2012 VW Turbo beetle
      08-01-2012 01:57 AM #76
      Quote Originally Posted by Babie View Post
      Ridge, makes sense, the dealer said he tried to order the motors under the old number, and now have new numbers. He said all his window motors for the old number were kicked out?
      Anyway, we may be at the end with the problems, let's hope,
      Perhaps VW has found a better motor manufacturer than was the case previously.
      Sep 27th, 2011
      Brooklyn, N.Y.
      08-01-2012 08:48 AM #77
      If anyone finds out the new part numbers for the window motors that Babie mentioned,
      please post them.
    3. Member plex03's Avatar
      Nov 10th, 2011
      Home of The NHRA U.S. Nationals
      '17 White CC R-Line Executive; '08 Honda Element
      08-01-2012 09:02 AM #78
      Quote Originally Posted by ridgemanron View Post
      Plex ! Are you having the 'upzy downzy' with both or only the driver's side? To be honest,
      my passenger side hasn't ever acted up but if a fix was available I figured it would be
      best to do both sides at the same time.
      Mine are now doing it on both sides. (after window motor replacement)
      The drivers side is every time now. It'll go down no problem but up it stops and goes down at either 1/3 or 2/3 no matter what.
      Passenger side right now is only about 50% of the time.
      It sucks but it's not unbearable. Just hope a fix truly is coming.
    4. Member
      Sep 27th, 2011
      Brooklyn, N.Y.
      08-01-2012 04:36 PM #79
      My service mgr said the window motor part numbers are still active in the VW system.
      The part numbers are 5C5-959-801-D-Z01 and 5C5-959-802-F-Z01
    5. 08-01-2012 05:24 PM #80
      My dealer today said he can't order any window motors in the system. He said they are trying to produce more, so maybe this is the caca culprit. I hope so.
      Anyone know
    6. 08-01-2012 05:26 PM #81
      Quote Originally Posted by plex03 View Post
      Uggggg...were they the Mexican motors or the German ones, ask your dealer cuz I did find out that the German ones were the better ones.
      I CAN'T UNDERSTAND WHY THEY CAN PIN POINT THIS PROBLEM. REALLY IS THIS A MONEY ISSUE
      Sep 27th, 2011
      Brooklyn, N.Y.
      08-01-2012 05:29 PM #82
      Anyone know
      When I 'Googled' the window motor numbers I did find VW dealers who had them in stock,
      but I feel if they are the same ones everyone is having problems with, there doesn't seem to
      be any logic in trying to have them installed. Let's hope VW gives us some info as to where
      they stand concerning our needed 'fix'. Will check with my service mgr every day or so to see
      if he has found out anything.
    8. 08-01-2012 05:30 PM #83
      we need some of you to check your local lots and ask to test the windows on the 2013 please and post your findings to this thread.
      THANKS
    9. 08-01-2012 05:50 PM #84
      I just called my dealer and they will say made in Germany on the motor. stay away from Mexican motors. Mmmm sounds like a south of the border car company.
    10. Member VWNDAHS's Avatar
      Jun 20th, 2002
      San Diego
      eGolf, 997TT, SQ5, Beetle
      08-01-2012 06:17 PM #85
      Not a money issue, a trial and error solution. Same thing we saw with the massive DSG recall, took a while to sort out what had failed and what production run.
    11. Member sethdude's Avatar
      Jun 27th, 2012
      St. Louis
      2012 GTI, 2012 Beetle, 1984 GTI, 1996 Buick Roadmonster
      08-01-2012 08:11 PM #86
      Babie, you are strange. Likable, but odd.
    12. 08-01-2012 08:13 PM #87
      Quote Originally Posted by sethdude View Post
      Thanks, my boyfriend says that to. But I do get all A's in college.
    13. 08-02-2012 07:12 AM #88
      You know that's not good, right???
      Einstein failed 8th grade math and Ferdinand Porsche - creator of the old Bug, Technical Director at Mercedes-Benz, and designer of many Third Reich armed vehicles - never officially went to college.
      And me.... I'm a genius in my own mind. My genius-ness tells me VW NEVER fixes anything quickly, particularly windows. Actually, they often move at glacial speed when it comes to window regulators.
      Or... it could be the JaegerMeister talking.... typing.
    14. Member RedTurboS's Avatar
      Sep 17th, 2005
      Atlanta
      2003 New Beetle Turbo S; 2013 Reef Blue Beetle Turbo w/ s/s/n
      08-02-2012 07:18 AM #89
      I just picked up my 2013 Turbo Beetle last night. So far the windows are fine but I have had it for less than 12 hours. Haha
      I'll keep you posted how mine does.
      ~Matthew
    15. 08-02-2012 07:50 AM #90
      It's always a money issue. More money for them and less for us.
      It's just accounting...
      Vw (credit)
      Vw Owners (debit)
    16. Moderator silverspeedbuggy's Avatar
      Aug 8th, 2001
      Cleveland Heights OH
      2015 GTI, 2006 GLI, 1987 Scirocco 16V, 1989 Jetta GL
      08-02-2012 08:26 AM #91
      Hi all -
      By now we've established there is an issue with 2012 Beetle windows. Here's what we know so far:
      - Windows lower with no problem
      - When using the 'auto-up' feature, the window only raises part of the way, then lowers quickly
      - It appears pinch protection is kicking in
      - It then takes a number of 'ups' and 'downs' to get the window to finally close resulting in the 'auto-up' feature to then be disabled
      - A TSB (Technical Service Bulletin) was issued to dealers with instructions to replace the gear guides and motors
      - The TSB repair did not cure the problem and was recalled
      - VW IS WORKING ON A REPAIR though no updates other than dealer rumors have been given on what the repair is and when owners can expect the repair
      - It is not yet known if the 2013 Beetles just arriving at dealerships have this problem
      With all the above in mind, this is now the OFFICIAL Window Thread for the Beetle.
      If you have an issue with your window, or an update, or a suggestion, post it here. The best way to stay informed is if we have all the information in one place rather than scattered around miscellaneous posts on this forum.
      This post is stickied, and I will update this first post as new information is disclosed.
      Also, I will be condensing posts into this sticky over the next few days.
    17. Moderator silverspeedbuggy's Avatar
      Aug 8th, 2001
      08-02-2012 08:34 AM #92
      On a more personal note, I struggled with creating this post. I'm a pretty firm believer in letting you all talk this out, but I feel it's gotten to the point that we need to have all the information in one place. It's difficult to find out any real information when there are posts all over.
      I also want to tell everyone here that is having a problem, I really feel for you. I think there's nothing worse than buying an expensive product and not have it live up to your expectations. I don't mean to stifle or restrict your ability to vent here with other owners, so I hope you understand that. It truly is one topic so I feel that we should keep one thread to this one topic.
      As a fairly new moderator, I'm sorting through my responsibilities here. I read almost every post, and you are all a great bunch of people. Your positive attitudes and mature postings make my 'job' easy. So thank you! This allows me to keep a pretty 'hands-off' approach to this area of Vortex. I believe we can keep it this way for awhile.
      I hope this helps all of you struggling with this annoying issue understand the need to make this change. Feel free to PM me if you have any questions or want something added. I'm completely open to feedback!
      - Chris
    18. 08-02-2012 09:04 AM #93
      OK cool thanks
      PS my brother is checking on some 13" today, He is in college on the east coast. The are some 13's there. He will let me know later today. I sent him a video of mine to compare.
    19. "Everything Is Awesome!" Moderator LC6X's Avatar
      Nov 2nd, 2006
      Portland, OR
      2001 Baltic Jetta, 2007 Fahrenheit GLI
      08-02-2012 09:15 AM #94
      Glad to see it all centralized
      A little update on mine: First thing I have to say is my dealer rep is absolutely AMAZING! I had it scheduled to have the part replaced yesterday, so I dropped it off after work Tuesday around 3:30pm. I get all call at 5pm from my tech saying that he had some extra time and already took care of it
      I wasnt able to pick it up until yesterday, because thats what I arranged with my ride. Got home from work, go to roll my window up and it goes right back down. I called my tech, left him a message to give me a call back whenever. I wasnt in a huge hurry since I knew going into this it was a known issue and probably wouldnt be fixed. He gave me a call back right away saying he forwarded my issue to VWoA and as soon as he got a response he would call me back again. 10 minutes goes by and he is calling me again to let me know it has been escalted through VWoA, and they are looking into the issue. Funny thing is as of this morning it seems to be working fine, going to have to see how long that lasts
      Although imo this should be a standard for service, we all know it isnt. Being an employee of Volkswagen I know that when it comes to the dealers we seem to be at the bottom of the totem pole, but its clear that, at least with this tech, he puts any issue at the top of his priority list
      Meet Crayola | Fahrenheit GLI #863 | IG: @mindy13vw | 8v Society | #TPG
    20. Member
      Sep 27th, 2011
      Brooklyn, N.Y.
      08-02-2012 10:22 AM #95
      In a nutshell, the pinch-protector, when activated, is overly sensitive and its inner
      brain mistakenly thinks that an obstruction has been placed in the path of the upward
      going glass, when in fact no obstruction seems to be there. If there were to be an actual
      obstruction in the inner window/door cavity, the problem should occur all the time, not
      just part of the time. Perhaps there is a faulty micro-processor of some kind that was
      accidently built in to the motors by the supplier of them and if so, VW should go over
      every conceivable electronic related possibility for the problem and fix it. We are not
      talking brain surgery here, but something a team of VW engineers should have been
      able to correct months ago.
    21. 08-02-2012 11:30 AM #96
      I know someone who checked some on a lot, all he said ALL worked great and he said smooth and quiet.
      So here, since I am holding the bag, I'll pass it on. As my grandma would say.
      He was there looking at a GTI anyway.
    22. Member sonic_va's Avatar
      Jul 2nd, 2006
      Arlington, VA
      2015 Audi A3 1.8T
      08-02-2012 11:36 AM #97
      Well, mine didn't act up right away either. It was not until about 1 month or 2 later when I started seeing the issue.
    23. 08-02-2012 12:20 PM #98
      It ain't over till the fat Beetle sings!!!
    24. Junior Member
      Oct 25th, 2011
      Cleveland, OH
      2012 Beetle in Toffee Brown
      08-02-2012 05:20 PM #99
      I still don't understand why they don't disable the auto up feature. No need for pinch protection if you have to manually hold the button to make the window go up. God forbid we have to engage our fingers for 30 whole seconds.
    25. Junior Member
      Oct 25th, 2011
      Cleveland, OH
      08-02-2012 05:20 PM #100
      Mine went 4 months before all hell broke loose.
