I don't think that Wilwood makes back ones for the MkIV. If you're needing stronger brakes for the rear, you can get 337 brakes on the rear, which are vented rotors, and get the slotted/drilled rotors and good pads with braided brake lines. For an "upgrade", thats about as good as it gets.
HS TUNING
