Results 1 to 2 of 2
Thread: HELP 01M - no codes, but very delayed shift from N to D
  1. 08-02-2012 11:35 AM #1
    Hello, i am from Berlin Germany and hope that somebody can help me.
    I got an 98' 1.6 with 01M AT and it has the following issue :
    If i switch from N to D it delayes estimated 4 seconds until the gear lockes.
    There is no code set told a friend, he has read out and had a look on the switch flags for the solenoid valves.
    If i switch from N to D the Valve N92 switches to 1 an is set for some seconds !? then if the gear is locked the flag switches back to 0.
    Does anybody has a tip what the error/fault could be ?
    Thanks
    Michael
  2. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
    08-02-2012 02:27 PM #2
    Check the fluid level first.
    If the fluid is full you proably have pressure loss that will require rebuild or replacment.
    Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
    ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
    www.KansasCityTdi.com
