Bad thermoswitch?
#1
02 MV. 80k miles. Secondary or auxiliary fan...whatever u call it...problem is it comes on all the time. Van might have only been running 2-3min and it starts running very fast for short bursts. Does it in hold and cold situations. Any ideas appreciated
WTB Tornado Red Mk2 Jetta rear pass door
WTB WTB: 16v 268 or higher exhaust cam only.
#3
Which one?....
http://www.germanautoparts.com/Volks.../Cooling/181/3
#4
Could be this?
http://europarts-sd.com/switch-radiatorfan1994-2003.asp
I'd say disconnect the wire connector and see what happens (if the fans quit switching on).
Or could be this one:
http://europarts-sd.com/sensor-coola...e1992-2003.asp
The ones at germanautoparts.com...the only one that might be possible is the green one. The blue 2-pin one I don't believe is for a later model.
