Results 1 to 4 of 4
Thread: Need help. Auxiliary/Secondary fan
  1. Member CHETVW007's Avatar
    Jul 25th, 2001
    Carlisle PA
    2002 Eurovan, 1992 Jetta GLi 16V
    08-02-2012 12:14 PM #1
    02 MV. 80k miles. Secondary or auxiliary fan...whatever u call it...problem is it comes on all the time. Van might have only been running 2-3min and it starts running very fast for short bursts. Does it in hold and cold situations. Any ideas appreciated
    WTB Tornado Red Mk2 Jetta rear pass door
    WTB WTB: 16v 268 or higher exhaust cam only.
  2. 08-02-2012 01:09 PM #2
    Bad thermoswitch?
  3. Member CHETVW007's Avatar
    Jul 25th, 2001
    Carlisle PA
    08-02-2012 02:10 PM #3
  4. 08-02-2012 02:21 PM #4
    Could be this?
    http://europarts-sd.com/switch-radiatorfan1994-2003.asp
    I'd say disconnect the wire connector and see what happens (if the fans quit switching on).
    Or could be this one:
    http://europarts-sd.com/sensor-coola...e1992-2003.asp
    The ones at germanautoparts.com...the only one that might be possible is the green one. The blue 2-pin one I don't believe is for a later model.
