Results 1 to 3 of 3
Thread: Gauge cluster issues....
  1. Member vr2jetta's Avatar
    Dec 16th, 2007
    canton ohio
    81 Rabbit pickup, '77 30' travel queen
    08-02-2012 12:16 PM #1
    So I have an 81 caddy with a g60 swap. I didnt do the swap myself, I traded my mk2 vr6 swap (which I DID do myself) for it. It has the g60 gauge cluster and everything works fine except every time I turn the key off the clock goes back to 12:00 and the trip resets. I am installing a new dash a picked up an mk3 cluster due to its smaller size and it does the same thing so Im thinking its a wiring issue. From the cluster i have a plug with a ton of white wires that plug into fuse panel but the 6-7 random colored wires are not plugged into anything, with the exception of the plug with the double wire. Anyone have any ideas? I have gone through the bentley but it doesnt help considering I have a hard time reading wiring diagrams anyway. Thanks.
    Forgot to mention, the truck is running a ce2 fusebox.
  2. 08-02-2012 02:42 PM #2
    sounds like the constant live isnt connected properly, check that d8 is jumped to e2 and that'll give you constant live for the clocks
  3. Member vr2jetta's Avatar
    Dec 16th, 2007
    canton ohio
    08-03-2012 06:07 PM #3
    I thought the d8 e2 jump was to get the gauges working in general. My gauges work just doesn't remember the time or trip. I believe the the d8 e2 is connected, I changed the fuse panel the other day but I'll double check.
