Results 1 to 8 of 8
Thread: How to perform a Throttle Body Alignment - The Movie!!!
    Jul 19th, 2010
    In the south, but not the "barefoot and toothless" south.
    2004 VWs
    08-02-2012 12:57 PM #1
    Jef blah blah blah
    http://www.ross-tech.com
    071, 070, 034, 036, 046, 077
    Mar 22nd, 2012
    Southern California
    2012 Tiguan SEL w/boost gauge and Scangauge
    08-02-2012 10:07 PM #2
    What are the consequences, if any, of not doing this procedure after the battery is disconnected and reconnected?
    Mar 22nd, 2012
    Southern California
    08-05-2012 12:47 PM #3
    I take it then from the lack of responses that a throttle body alignment is only of academic interest after a battery disconnect?
  4. Member bluewolf2001's Avatar
    Aug 24th, 2011
    cincinnati, ohio
    2001 wolfsburg jetta, audi a4 2.8 avant
    08-08-2012 01:02 PM #4
    i only have access to vcds lite. can it be performed throught that???????
    also i took my throttle off cleaned it, never performed a alignment but my throttle doesnt even work now at all. it used to click when i turned the key on. but now their is no noises
    Mar 22nd, 2012
    Southern California
    08-08-2012 09:44 PM #5
    I had to disconnect my battery the other day to install a NewSouth Boost Gauge, and other than having to reset the time of day on both the MFD and the RNS-510 Nav unit, have not noticed any issues with the throttle.
  6. Member
    Jul 19th, 2010
    2004 VWs
    08-08-2012 10:02 PM #6
    On some of the older Drive by Cable engines, then engine will not run until a Throttle Body Alignment is performed. It is good practice to do on any vehicle once power is restored, it gives the ECM a base line reading to work from on the Throttle Body.
    The full version of VCDS-Lite can the Throttle Body Alignment.
    Jef blah blah blah
    Mar 22nd, 2012
    Southern California
    08-09-2012 06:59 PM #7
    Thanks for the clarification. My 2012 Tig is at the dealer today for a transmission reflash (hopefully) and a gas mileage issue, we'll see if they even do a throttle body alignment if they think it will have any impact.
  8. Member bluewolf2001's Avatar
    Aug 24th, 2011
    cincinnati, ohio
    08-09-2012 10:59 PM #8
    my car is a drive by wire thou i think....its a 2001 AWW motor......it startes just nothing when i hit the gas peddle. it may go up 200rpms but nothing more.
