Results 1 to 11 of 11
Thread: 2010 Sunroof Troubles in Hot Weather
  1. 08-02-2012 02:28 PM #1
    Hi - had my sunroof completely replaced last summer - in hot weather something is expanding and the rails bind up with lots of nasty squeaking noises - hot weather here again and new roof doing the same - is this a common fault - is there a tech bulletin on it - is there a proper fix - inconvenient while under warranty but at 10 hrs labour plus parts not something i want to deal with post warranty? Thx Chris
  2. n00b travman32's Avatar
    Apr 25th, 2012
    West PA
    08-03-2012 02:33 PM #2
    Our '12 JSW sunroof broke at 2,700 miles - they had to replace the entire assembly, had our car for a week.
    It happened on a 90+ degree day, so perhaps heat is doing something?
  3. Member leroyal's Avatar
    Jun 5th, 2006
    The City That Bleeds.
    2011 JSW TDI
    08-03-2012 06:40 PM #3
    I just noticed my pano roof has no grease on it. Both my 02 JSW and 05 Passat wagon both had lots of grease on their rails.
  4. Geriatric Member rootrider's Avatar
    Feb 18th, 2004
    Midland, WA
    '09 sportwagen tdi, '95 e36 m3
    08-03-2012 10:24 PM #4
    definitely make sure the rails are well lubed..
    yes, it is common to get noises from the roof in hot weather
    PNWfahren - Pacific Northwest Regional Car Enthusiast Forum Community
    2009 VW SportWagen TDI info, mods, & pics =-=-= 1995 BMW M3 coupe
    driven: The Ridge Motorsports Park, Pacific Raceways, Portland International Raceway, Oregon Raceway Park, Nürburgring Nordschleife, Harris Hill Road
  5. Junior Member
    Jul 16th, 2010
    Toronto, Canada
    08-03-2012 11:49 PM #5
    Noticed the same thing, Mentioned it when I went in for my oil change, I guess they lubed it up cause it stopped. Didn't charge me anything.
  6. Junior Member
    Nov 15th, 2010
    Glendale, AZ
    08-04-2012 01:59 PM #6
    My sunshade stopped working at 70k and my roof is starting to make noises despite them being properly lubed. My theory is that the car does so much twisting up there (sounds like a wooden ship entering driveways) and that any resistance on that motor will burn it up quickly.
    Sad to say, but I try to only use the pano when it's a very nice day out.
    http://www.pankaked.com
    THE blog about all things low...
  7. Member zagato27's Avatar
    Sep 16th, 2007
    The Hill, GA
    2012 JSW TDi CW Titan 6MT Pano Nav Portos
    08-04-2012 05:56 PM #7
    Had my '12 w/ pano for a year and no problems with leaks or squeaks(fingers crossed)AND it's been DANG hot here in the Savannah area. Next service, 20k, may have them check on lubing the rails. I think that on either the 20 or 30k service they are supposed to clean/clear the drain lines and lube. Have to check the manual.
  8. Member ajd187's Avatar
    Feb 6th, 2012
    Palmyra, NY
    08-07-2012 09:52 AM #8
    The roof on my 09 was sticking a bit, and it scared me with all the problems I had read about on here.
    I busted out a tub of waterproof grease (I use this on my dirtbike bearings which see way more harsh use than the pano roof) and lubed it up.
    Problem solved for now, and that grease should last a LONG time.
    2009 Jetta Sportwagen SE
  9. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    08-07-2012 10:47 AM #9
    Quote Originally Posted by ajd187 View Post
    Good idea.
    ECSTUNING | GO APR
  10. Member cwescapexlt4x4's Avatar
    Jan 2nd, 2003
    Litchfield Park, AZ area
    2011 JSW TDI DSG Salsa Red, 2011 Kia Optima SX (Turbo) / previous 97 Jetta GT & 91 Passat wagon
    08-08-2012 10:38 AM #10
    I have lubed ours up and will again after the summer and I remove my extra sunshade between the worthless "shade" as in AZ it's worthless so we don't use the Pano all summer.
    2013 JSW TDI, Nav, Kessy - White, Pano roof, Canvas Back dog/cargo liner
    13% tint, 30% on Pano, Fog lights, rear spoiler, mud guards, (to be installed).
    Replaced - Trouble free 2011 Sportwagen TDi Salsa Red. Oo>=====v=====<oO/
    2011 Kia Optima SX (Turbo) Corsa Blue - 13% Tint, LED interior lighting, "Big Boy" horn, T badge. BFGoodrich G-Force Sport Comp 2
  11. Member ajd187's Avatar
    Feb 6th, 2012
    Palmyra, NY
    08-08-2012 11:09 AM #11
    I also should say, I lubed the joints as well as the track.
    I pressed the dealer on this and they did lube it before I took delivery (CPO car) with white lithium grease. They used a little but probably not enough.
    I use the waterproof stuff on dirtbike suspension joints that see water, mud, and pressure washer use sometimes. Way harsher environment than pano roof tracks that sit in a dry car and slide open a few times a week, whichi s probably why it works so well.
