Results 1 to 4 of 4
Thread: Front end clacking noise (metal on metal)
  1. 08-02-2012 05:42 PM #1
    '03 Jetta GLI. Had ECS stage 3 suspension refresh kit installed. After this, the following noise appeared, which didn't exist before the parts refresh:
    http://soundcloud.com/t5un4m1/clacki...from-front-end
    Any clues? So far guesses are swaybar related or strut mounting plate. The top nuts appear to be tight.
  2. Member iSpeed's Avatar
    Jul 20th, 2009
    Hi Life
    05 GLI
    08-02-2012 09:47 PM #2
    I had a issue like this a few years back after I install new front Hawk brake pads on my GLI. I racked my brain on the cause and cure. I only heard the sound when I hit bumps but could not be heard when I applied the brakes. Turned out that the brake pad shim either fell out or was not installed and the pads were rattling inside the caliper when I hit bumps and was not on the brakes. Thats **** drove me NUTS!!!
    Quote Originally Posted by Gbeav View Post
    DSG is awesome, sorry.
  3. n00b
    Aug 2nd, 2012
    brighton mass
    03 gti vr6
    08-03-2012 10:36 PM #3
    sounds bad but heard alot of wind noise tho sounds like a bad strut tho if not that id check the strut mount it could be a bad bearing on the shock itself i had that problem sounds close
  4. 08-04-2012 11:06 PM #4
    did you replace all the one time use stretch bolts?
    one time when i dropped my subframe i did not get a bolt completely secure, it kinda sounded like what you have on the clip.
