Results 1 to 10 of 10
Thread: MKV R32 Hella LED taillight warning light issue
  1. Junior Member jar4610's Avatar
    Oct 27th, 2009
    Chicago
    2008/Volkswagen/R32
    08-02-2012 05:58 PM #1
    Hi, I have recently installed a pair of HELLA LED tail lights for my MKV R32 and there is a yellow indicator light showing in my dash board telling me that both my tail lights are not working, but they are working. I was wondering if anyone else who installed these tail lights had this same issue and if they did, how did they manage to solve it?
  2. Member DarkNeo's Avatar
    Jun 18th, 2004
    SoCal
    Golf R32
    08-02-2012 06:04 PM #2
    Are you running the proper wiring for those lights? and also did you code them?
    Official OG '08 .:R32 Owners Club Member
  3. Member ZPrime's Avatar
    Mar 7th, 2006
    [216 / 440] Mayfield Heights, OH
    2008 R32 #3603/5000
    08-03-2012 01:50 AM #3
    What DarkNeo said. In my experience, the actual OEM LED tails, when wired properly, can be run with all of the "bulb checks" enabled and you won't get warnings.
    In fact, a small portion of one of my turn signals or outer red ring is actually intermittent, and even THAT doesn't trigger the bulb warning.
    If you are using hack harnesses/etc, that could cause errors, I don't know. I did it the "Right" way and ran wires.
    I have installed most of the popular bolt-on mods for a 2008 R32, minus suspension work. I know a lot about electronics and car audio, and have experience with VCDS ("vagcom"). I'm a radar/lidar countermeasure enthusiast. I like track days, autocross, and US Highway 129. I love aural pleasure.
    WitW 2013 || I UM
  4. Junior Member jar4610's Avatar
    Oct 27th, 2009
    Chicago
    2008/Volkswagen/R32
    08-03-2012 04:44 AM #4
    I am almost sure it is the wiring. The coding should be correct. I just do not have any idea what type of wiring problem it may be.
  5. Member euroluv69's Avatar
    Dec 6th, 2006
    08 R32 #2159
    08-03-2012 09:35 AM #5
    anyone have a link to the vag com coding??? seems all i can find are for the GLI.
    I have the OEM Euro LEDs and having the same issues...ran the trigger wire and what not, everything works, but rear fog and no amber turn signals.
  6. Member ZPrime's Avatar
    Mar 7th, 2006
    2008 R32 #3603/5000
    08-03-2012 07:38 PM #6
    Quote Originally Posted by euroluv69 View Post
    Trigger wire isn't enough, that just enables the fog light. You still have to run two more wires from the CECM to the back to give yourself a separate light for "running lights," and then the blinker will be amber after you swap some pins around at the light plug.
    WitW 2013 || I UM
  7. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    08-03-2012 08:58 PM #7
    Quote Originally Posted by ZPrime View Post
    AFAIK, the oem euro leds are made by valeo. Don't have the part number on hand.
    I know Hella is an oem manufacturer but perhaps not necesarily for us and euro-spec vw's i.e. japan, mexico, etc.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  8. Junior Member jar4610's Avatar
    Oct 27th, 2009
    Chicago
    2008/Volkswagen/R32
    08-03-2012 11:13 PM #8
    Would this be a general write up on how to fix this issue?
  9. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    2008 VW R32 :: 2000 MBZ ML55 AMG :: 2006 Mini Cooper S :: 2003 Aprilia Atlantic 500 :: Yam. Morphous
    08-03-2012 11:42 PM #9
    Search for "LED" in titles.
    http://forums.vwvortex.com/showthrea...&highlight=Led
    Above link is one example. In my experience, there is not one linear thread to guide you. You have to wade throught it.
    One of the confusing bits is the schism between those who run wires the length of the interior (often called the "right" way) and those who either modify the wiring at the taillight or run a short adapter harness to do the same thing. This latter bit is sometimes called the ghetto way. I went the ghetto way.
    It's been too long since I did it for me to guide you step by step. I'm happy with my amber turns, and no errors from these. I bought the trigger wire for the fog, but I've never run it to the main ccm.
    Quote Originally Posted by petef View Post
    ... you have no way of knowing whether the previous owner(s) was a civilized driver or a hoon like Peach.
    Quote Originally Posted by Dave Barry
    Wouldn't "Hoon Like Peach" be an awesome band name?
  10. Junior Member jar4610's Avatar
    Oct 27th, 2009
    Chicago
    2008/Volkswagen/R32
    08-03-2012 11:52 PM #10
    Thanks man I am going to give this write up a shot and see how things go.
