VWVortex.com - CTS R32 SRI install HELP!!!!HELP!!!!HELP!!!(Dont scroll over me please lol)
    Results 1 to 16 of 16
    Thread: CTS R32 SRI install HELP!!!!HELP!!!!HELP!!!(Dont scroll over me please lol)
    1. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      2003 GTI 24v // 2007 CBR600RR // 97' F150 // 85' Honda ATC 200x
      08-02-2012 06:50 PM #1
      I just got my R32 cts SRI yesterday, i got it bolted on, no problems there! once i bolted the TB on the where it got scary! The main coolant line coming from the coolant housing to the radiator, litterally would have to go through the TB because the new TB mounting spot is almost right in front of it! here is a pic.........
      ..."understeer is when you hit the wall with the front of the car, and oversteer is when you hit the wall with the back of the car"...
    2. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-02-2012 08:19 PM #2
      there has to be someone out there thats installed this intake and ran into this problem......
    3. Member Sn0wMaN's Avatar
      May 25th, 2003
      Grand Forks ND
      91 GTI VR6, 08 .:R32
      08-02-2012 09:35 PM #3
      I'm confused, u removed the tb to install SRI? Pic didn't work.
      91 GTI VR6 - 13.8 @ 98
      #2139 - 08 DBP R32- 14.48 @ 94 - stock Now: Weapon R CAI, custom full exhaust: ported manifolds, 2 1/4" downpipes, hf cats, 2.5" Magnaflow, and flex fuel kit with UM software.
    4. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-02-2012 09:52 PM #4
      Quote Originally Posted by Sn0wMaN View Post
      well yeah.....i kinda had to? I replaced the plastic old stock intake mani for this HPA clone SRI mani. The TB(throttle body) was up at the back of the motor (stock), now its down in the front, which is where im running into this problem....
    5. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-02-2012 09:53 PM #5
      Did you think i ment i removed the thermostat housing to install the SRI? cause of course i had to remove the TB
    6. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-02-2012 10:07 PM #6
      Possible solution......fabricate a flange to bolt to my SRI and weld a tube to it(to allow for clearance), bend it whichever direction i need, weld another flange to it the other end for the TB.......
      more input please
    7. Member Sn0wMaN's Avatar
      May 25th, 2003
      Grand Forks ND
      08-02-2012 11:47 PM #7
      No I didn't think thermostat, I didn't realized you got a new manifold, just thought it was the intake!
    8. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-03-2012 12:25 AM #8
      ooohhh that makes sense!
    9. Member SMG8vT's Avatar
      Oct 8th, 2004
      Nova Scotia
      '00 Beetle R32, '66 Beetle Project, 2011 Jetta TDI Highline
      08-03-2012 01:04 AM #9
      Did you put an R32 intake on your 2.8L 24v? Just going by your profile.
    10. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-03-2012 01:19 AM #10
      Quote Originally Posted by SMG8vT View Post
      No its a hybrid project, its an R32 cylinder head on a 2.8bdf block
    11. Former Advertiser
      Jun 24th, 2009
      Summit, NJ
      Billet 72'd 07 GTI, Billet 6265'd 08 R32, 2010 GMC Sierra
      08-03-2012 02:41 PM #11
      You need to cut the tb and use a shorter bolt.
    12. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-03-2012 05:13 PM #12
      Quote Originally Posted by JC@DouglasVW View Post
      Thats genious! why didnt i think of that?? haha thats why its nice to have this forum! also since i wasnt planning on hooking the coolant lines back up to the tb, do you think i can just cut that off aswell? its kindve pinching my coolant hose pretty bad.....what do you think
    13. Former Advertiser
      Jun 24th, 2009
      Summit, NJ
      08-03-2012 09:42 PM #13
      If you don't want to use the coolant lines to the tb don't use them, that is 100% fine.
    14. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-03-2012 11:10 PM #14
      so if i cut off that little coolant chamber on the tb it wont compromise the tb right?
    15. Member joeeveryman87's Avatar
      Dec 6th, 2010
      South Dakota
      08-05-2012 11:54 PM #15
      Thanks to "JC@DouglasVW" simple but awesome suggestion, my problem is about 90% solved, just gonna have to wrap the coolant line with something to help prevent chaffing!
      This was my simple quick fix.......
      just need a new shorter bolt, nothing that fastenal cant help me with. EASY fix!
    16. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      01001011010011110 1010010
      09-26-2012 03:15 PM #16
      Check the internals of that clone manifold... People have reported "cast spatter" in the log or runners and if it comes off... Bye bye motor If there's cast debris remove it.
      "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
      2008 Mkv-sold; 2003 yellow SRT-4-sold; 2009 G8 GT-sold; 1991 Talon TSI- fully built-sold ; 2011 Mk6
