Change it it should be 0 ohm.
#1
What's up people? I am new to the 24v VR6 and am having problems with my jetta starting. Car can be hemp started or jumped. Already cleaned cables and grounds, no loose connections, but there is 35 ohms resistance in the negative cable from the battery terminal to the block after it splices out from under tray. What is the specification for it and what is the likelyhood of this happening?
