Results 1 to 8 of 8
Thread: 1.6L N/A injector rebuild questions
    Feb 20th, 2012
    East Coast
    2004 R32, mk4 Jetta (sold), mk2 diesel, MK1's
    08-02-2012 07:44 PM #1
    want to rebuild all four, cant find a solid website that looks good. anyone knows of a place local in NC, or a good online site please let me know
    the shortest distance between two points is under construction
  2. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    08-02-2012 08:53 PM #2
    Did you contact Giles or the diesel shop in Garner? You should also have some Bosch diesel shops closer to you, but the one in Garner is known to be good, as we've used them before.
    (I saw your thread on NCDubs)
    Quote Originally Posted by TM87 View Post
    VW-making mechanics out of owners since 1957.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
    Aug 16th, 2010
    Waterloo, IA
    Blk 98 Jetta GLX
    08-06-2012 06:36 PM #3
    I've had to 'rebuild' mine several times since i've got my car. It's not horrible hard, just have to be patience and make sure you THOROUGHLY clean everything. I had a needle in one of my injectors break before while i retorqued the halves together. I never calibrated mine, just wanted it to run so i could drive the damn thing. Haven't had any problems for nearly 10,000 miles now. Couldn't get the halves to seat properly the first couple of times through. I also soaked all the parts in ATF over night just for some reassurance.
    "VR no longer stands for VR6, it's now Velociraptor... which is pretty much how a VR6 sounds like."
  4. Member burn_your_money's Avatar
    Oct 4th, 2004
    Bright, Ontario Canada
    6.9L F250
    08-07-2012 05:33 PM #4
  5. Member janb's Avatar
    Oct 24th, 2000
    PNW - Columbia Gorge
    08-12-2012 07:26 AM #5
    I just buy new nozzles for mine, and keep the existing shims. ~ $11 each.
    Rebuilt ones are $30 w/ core exchange.
    Vince's write-up, is right on track.
    Home of the $35 VW-D
    (look in your neighbor's brier patch to find your next Rabbit )
    (25) VW-D's IDI's & (3) B4 TDIs and various other clattermobiles
  6. Member Bierbursche's Avatar
    Aug 30th, 2005
    tdcpa
    85 westmoreland golf diesel and a 90 coupe
    08-14-2012 07:02 PM #6
    hansdieselparts.com
    2/2/09
    ~Side Street Euros~
  7. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    08-14-2012 08:13 PM #7
    Quote Originally Posted by Bierbursche View Post
    hansdieselparts.com
    No. Just no. That's Prothe. Search his name. Stay away. I've seen stuff on his injectors...pure garbage.
    Pay the extra money and get them from someone reputable.
    Mar 31st, 2008
    PNW - Oregon
    08-15-2012 06:56 PM #8
    Quote Originally Posted by Rockerchick View Post
    i remember someone over on the homefront (vwdiesel) is running prothe injectors, and they start/run.. no word on the break pressures, or anything like that.. but they do run..
    not saying they are a good option, cause i would only consider them if they were the last injector on the face of the earth..
    either send them to a good shop and have them rebuilt, or follow the vince waldon write-up..
