Results 1 to 16 of 16
Thread: NGK plugs...FYI
  1. Member 1955oval's Avatar
    Jun 17th, 2009
    Sewell, NJ
    1955 oval, PG 04.5 GLI
    08-03-2012 12:04 PM #1
    Just got this off my club's website...enjoy
    http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
    APR R-1 DV...APR Tip...APR TBH...APR Stage 2...Maxpsi 3" TBE...Tryolsport SMIC
  2. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    08-03-2012 12:43 PM #2
    Quote Originally Posted by 1955oval View Post
    i never use that anti-seize and always have clean threads when i take out my plugs. the auto parts store always trys to pitch it to me tho
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    Jun 21st, 2010
    Darlington
    08-03-2012 12:55 PM #3
    Auto-store: "Be sure to get some anti-seize."
    Me: "Not needed, but thanks."
    Auto-store: "You'll be sorry when they get stuck"
    Me: "OK"
    Every. Damn. Time.
    GLI / 1.8T / F23 / 550cc / Autotech Cam
    912 / Widebody / EJ20T / 915
  4. 08-03-2012 12:58 PM #4
    Quote Originally Posted by Big_Tom View Post
    What do you use to clean the threads out in the head? or do you just clean the threads on the plugs?
  5. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-03-2012 01:15 PM #5
    Quote Originally Posted by Dub-Nub View Post
    i usually dont clean the threads in the head. i have a small brush i have used before tho
  6. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    08-03-2012 04:17 PM #6
    FAQ'd
    My Build
    FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
    FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
  7. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-03-2012 04:26 PM #7
    Quote Originally Posted by groggory View Post
    FAQ'd
    i knew you would be on this, you don't miss a beat with those FAQ's
  8. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    08-03-2012 04:40 PM #8
    If you make it, they will come.
    There is a lot of junk on this forum, but there is a lot of good information too. I hope these FAQ's I put together helps filter the good stuff from the bad for the average user.
    My Build
  9. 08-03-2012 05:21 PM #9
    I use antiseize everytime. Just a habit. Probably not that important.
  10. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    08-03-2012 11:00 PM #10
    I have used anti-seize on spark plugs for 10years and never broken a single plug. And after 40k miles they come right out and dont break coming out.
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  11. Member sabbySC's Avatar
    Dec 28th, 2009
    Toronto/Ottawa
    2003 GTI
    08-03-2012 11:25 PM #11
    In my case I have never used antiseize over the past 15 or more years of doing all my own maintenance and I have never had a problem. The only problems I've ever seen are from others who crank rediculously hard on their spark plugs because they don't know better.
    CTS gt3071r and more
  12. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-04-2012 07:32 AM #12
    Quote Originally Posted by sabbySC View Post
    this, and the ones who change their plugs every 100k miles
  13. 08-04-2012 12:21 PM #13
    Quote Originally Posted by Slimjimmn View Post
    indeed, a dab of anti-seize and torque them down correctly... done!
    Canadian Immo 2 and 3 defeat service, PM for more information.
    Stupid low KM 2.0L 16V for sale!
  14. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    08-04-2012 09:38 PM #14
    Both VW and Toyota both state though not to use antisieze.
    Then again, when you go 120k on plugs, they dont come out very easy. I have broken a few ones taking them out for the first time due to soo much carbon buildup on them. Especially ford triton 3v engines, dumb design, always break off.
  15. 08-05-2012 12:17 AM #15
    nice lil read.FWIW, i never use anti-sleaze on a plug.
    and never broke one.
    and i use my Armstrong torque gauge when installing (i go by feel)
    i change my plugs about every 15 miles of use or so. (that is about two track days)
    then again, on a drag car on my level plugs are a consumable at this point. i make around 6 passes at 9 seconds and change them. or do 5-6 dyno pulls and use two sets. the plugs i use are ultra cheap, too. i buy them in bulk and pay around $1.79 each for them!
    NGK R5671A-9 gapped to .020. pushing >43 psi on a rather large frame turbo and making well >800 AWHP.
    FWIW, not that i know anything! oh yeah, i like Widmer Hef (its local to me ) with a cut of lemon in it, whilst working on said racecar!
  16. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-05-2012 12:27 AM #16
    Quote Originally Posted by speeding-g6O View Post
    i use the armstrong torque gauge as well
