You might not get it off without breaking it, ECS sells just the seal if you need it.
#1
i've got a missing seal on golf's antenna, a buddy of mine has a jetta with the seal intact, problem is we don't know how to remove it, does it twist off? or pry off? and how is installation?
#2
#3
I was under the impression you need to get at it from underneath. As in partial removal of the rear part of the head liner.
I had to get my roof re-sprayed because my local dealer dropped the garage door on my rear roof and hatch. When i got it back the ******* tards never removed the base of the antenna to spray it properly. Too much work for them to correct a problem that was their fault. End rant-
Hope this helps-![]()
#4
thanks guys, i'll see if we can even get into his car, it was in a pretty serious roll over accident, so i dont think we can open any of the doors, lol. was hoping it would pry off or something, only reason i haven't ordered it from ecs is cuz its on back order, thanks again![]()
#5
To remove the antenna you need to take down the headliner. It's a 19mm (I believe) nut that holds the antenna in place. Not a fun job.
#7
#8
http://www.antennamastsrus.com/VW/VW...01999-2006.htm
can purchase just the gasket
#9
#10
#11
I just came across the antenna diagram in my bently manual. I'll take a snap shot of it and post later tonight. At work right now just cruising vortex![]()
#12
Sorry for the craptastic cell picture. It looks as though 5 is a nut with a serrated washer m14 I believe. Also torque spec is 7 Nm 62 in lb. Accessible from inside only.
Hope this helps.
