Results 1 to 9 of 9
Thread: :: ECS Tuning :: ECS Lightweight Underdrive Crank Pulley for VW 2.5L - In Stock !!!
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    08-03-2012 04:19 PM #1
    Lightweight aluminum crankshaft pulleys from ECS Tuning punch above their weight. Precision machined from anodized billet aluminum, our great looking upgrades bolt on easily in place of your portly stock pulley.
    Choose from stock diameter or underdrive. Either pulley reduces rotational mass for faster throttle response. The underdrive option reduces parasitic horsepower loss.
    The bare stock pulley works with your standard length accessory belt; the underdrive kit comes with a shorter Bando belt.
    Buy them for function. Because they look great. Or both!
  2. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    08-04-2012 05:12 PM #2
    How does your under drive version work with the battery? Still full power?
    2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
    Nov 28th, 2010
    07 Jetta WE, 07 F-350 6.0
    08-04-2012 11:05 PM #3
    Hmm... I'm considering one of these. Any tradeoffs/downsides or negative long term effects? Also looking up a DIY after I post this to see if its within my mechanical ability
  4. 08-06-2012 09:15 AM #4
    Tips for removing the stock crank pulley? It just spins when i yank on it with my breaker bar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    08-06-2012 10:39 AM #5
    Quote Originally Posted by chadone View Post
    You will see no battery issues or effects.
    Quote Originally Posted by PhAyzoN View Post
    Some of the damping properties are lost. Although we have tested these pulleys rigorously for many thousands of miles without any side effects.
    Quote Originally Posted by Vash350z View Post
    When taking the old pulley off it is better to leave the belt on crack the bolts loose, then remove the belt and pulley/bolts after.
    Holding the stock pulley in place can be done with a pry bar or screw driver within the spokes.
  6. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    08-07-2012 07:58 PM #6
    What do u mean by dampening properties?
    And there will b no issues with the battery not fully charging?
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    08-08-2012 01:53 PM #7
    The stock pulley has a certain weight to help tone down vibrations, with our kits you will loose that dampening - yet again still no problems.
    Still have seen no issues with battery/charging issues.
  8. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    08-11-2012 06:51 PM #8
    Quote Originally Posted by ECS Tuning View Post
    How much vibration can you feel?
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    08-13-2012 11:17 AM #9
    Even with some dampening lost, we have still not have seen this issue with customers or felt any added vibration with our kits.
