VWVortex.com - Rain Sensor...Where.
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 43
    Thread: Rain Sensor...Where.
      May 23rd, 2008
      Richmond, VA
      2013/VW/Passat TDI SEL
      08-03-2012 10:55 PM #1
      Where is the rain sensor? Just curious. I searched, and I see how to turn it on, but not where it was really located.
      Thanks,
      Loki
      Sent from my iPad using Tapatalk HD
      May 28th, 2009
      Ft. Worth, TX
      2009 JSW TDI; 2014 Passat TDI SEL;2014 Toyota Avalon Hybrid; 2013 Ford Cmax Hybrid; 2015 Nissan Leaf
      08-03-2012 11:09 PM #2
      Box-shaped object at the base of the rear-view mirror, where the mirror attaches to the windshield.
      Sep 23rd, 2002
      2012 Passat V6 SE (Night Blue ext / Black int)
      08-04-2012 02:47 PM #3
      You can see it on this video where the man pours water on the windshield, from the water bottle, directly in line with the sensor.
      http://www.youtube.com/watch?v=M2rC0wr0zno
    4. Member
      Apr 21st, 2012
      Millersville, MD
      2012 Passat TDI, 2005 Ford F-250 6.0 diesel, 5 2015 Lincoln MKZ Hybrid, 2007 Artitic Fox 5th Wheel
      08-04-2012 04:18 PM #4
      Speaking of this rain sensor.... what does the car have to see to close the windows and sun roof? I had a guy activate this for me and he claimed that REAL rain has to be present to activate this.... but here is this video showing just H2O being poured out of the jug....
      I can't get mine to do that! Can I assume he "forgot" something?
      2012 Passat SE TDI NAV
      2005 F250 PSD 4X4 LB CrewCab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover
      2007 Arctic Fox 30' Fifth Wheel
      Sep 23rd, 2002
      08-05-2012 10:27 AM #5
      Quote Originally Posted by BudPytko View Post
      If I remember correctly the sensor uses infrared light and it is measuring the amount of light that comes back to it. Raindrops will scatter the light and the sensor can detect that less infrared light is coming back to the sensor...it's raining.
      The same sensor is used for the automatic headlights.
    6. Member
      Apr 21st, 2012
      Millersville, MD
      08-05-2012 12:58 PM #6
      Well, the auto headlights work....looks like a programming error. Can anyone give me exact steps so I can go back to my guy and let him know what he did wrong? Appreciate it!
    7. Junior Member harivas's Avatar
      Jun 2nd, 2012
      2012 Passat 2.5 SEL Premium
      08-05-2012 01:53 PM #7
      With windows and sunroof open, stop the engine, get out of the car and close it. Pour some water at the sensor and see what happen.
      Apr 29th, 2012
      Mid-Coast Maine
      01 TDI Jetta, 02 TDI Golf
      08-05-2012 05:29 PM #8
      Quote Originally Posted by harivas View Post
      I haven't tested mine yet, but I think I read somewhere the doors have to be closed and locked for the windows/sunroof autoclose to work.
      Jim
      02 TDI Golf 5M- Black w/Black- RC3+ , PP520, VNT-17, Webasto, 290K miles, 58mpg
      12 TDI Passat SE 6M- Platinum Gray w/Moonrock- 52 mpg 12/16/16 Buyback
    9. Member compu_85's Avatar
      Aug 17th, 2004
      Springfield, VA
      08-05-2012 06:23 PM #9
      Yes, the car has to be locked for the rain closure to be active.
      -J
      2012 Passat TDI SE DSG. 99,000 miles. LED tails, VCDS tweaks (wipers, alarm, cluster)
      2004 Touareg V10 TDI. 150,000 miles.
      1999 Jetta "GLX" TDI. 309,000 miles. RCIII, BV49, S520, Knois.
      1991 Mercedes 350SDL. 230,000 miles, 60k on the replacement motor
      Past: 91 Jetta ECOdiesel. Totaled. 92 Jetta ECOdiesel. 87 Audi 5000S Q. 85 Jetta 1.8.
    10. Junior Member harivas's Avatar
      Jun 2nd, 2012
      08-05-2012 08:56 PM #10
      Yes, closed and locked.
    11. Member
      Apr 21st, 2012
      Millersville, MD
      08-05-2012 11:22 PM #11
      I did that......
      Quote Originally Posted by ixlr08 View Post
      I did that too......
      The gentleman who programmed it is stopping by tomorrow evening or Tuesday to recheck everything....that is why I wanted specific steps...... if anyone could leave that info here it would be great....and thanks to everyone that is trying to help.
      May 23rd, 2008
      Richmond, VA
      08-05-2012 11:25 PM #12
      Did you turn it on in the MFI?
    13. Member
      Apr 21st, 2012
      Millersville, MD
      08-05-2012 11:26 PM #13
      Quote Originally Posted by LokiWolf View Post
      There is a check mark there......
    14. Member
      May 28th, 2007
      CT
      Rusty n' Not Reliable
      08-06-2012 01:06 AM #14
      Read the instructions in the companion article to my video:
      http://www.myturbodiesel.com/1000q/b...ng-feature.htm There's even screenshots. If you have an SEL Premim, even the coding may be the same.
    15. Member
      Nov 30th, 2011
      2012 Passat V6 SEL Prem/Nav; 2012 Tiguan SEL Prem/Nav
      08-06-2012 02:37 AM #15
      Only other 'trick'.... Wait. The BCM has to go to sleep after hitting lock. One-three minutes then try to spray water over the top of the sensor again.
    16. Member
      Apr 21st, 2012
      Millersville, MD
      08-06-2012 12:56 PM #16
      Ummmm, don't know if it was that long I waited or not..... just went out and opened sunroof and windows. Will wait 5 minutes and see.......
      Nope - that didn't work either. Anyway, we're gonna check the install again. He's coming by with the cable later this evening or tomorrow.
    17. Member
      Apr 21st, 2012
      Millersville, MD
      08-06-2012 08:09 PM #17
      He missed checking a box. All's well now. VW needs to be teaching their dealers what this car will do!
    18. Member
      Feb 2nd, 2006
      South Central KY
      15 Golf TDI 14 F150
      08-07-2012 10:09 PM #18
      this info is added to the diy
      If you can't take the HEAT be a COP
      2B1 ask 1
    19. Member eurolok003's Avatar
      Mar 16th, 2009
      Pensacola, Fl
      VW Phaeton '06, VW Touareg '06, BMW 335 convertible '08
      08-08-2012 02:45 AM #19
      Confirm that rain-closing works on a 2013 TDI SEL. I had a real-world experience today leaving the sunroof open, then a thunder storm came. I was a little worried to be frank, until I walked out to the car and the sunroof was closed! The thing is, after I started the engine, the rain-sensing wiper did not respond to rain as it used to. I had to cycle the start-stop to reactivate the rain-sensing wiper.
      -Ming
      13 Passat TDI SEL, Rain-sensing wiper, rain-closing, seatbelt chime mod, recal mpg
      06 Phaeton V8, keyless start, paddles, wood steering wheel, remote window op.
      06 Touareg V8, keyless start, paddles
      08 BMW 335 convertible. Custom billet hard top hardware.
    20. n00b
      Jul 1st, 2012
      Aggieland, Texas
      2013 Passat TDI 6MT Reflex Silver/Moonrock; 2000 ALH 5M Jetta TDI
      08-19-2012 11:14 AM #20
      Quote Originally Posted by eurolok003 View Post
      I can't get it to work on mine. When I go into 09, CECM, Coding, the dropbox that is supposed to let me select RLS is greyed out and wont let me go to the RLS (rain light sensor). I wonder if mine has one?
      Anyone else have luck with this on a 2013?
      Jared
    21. Member
      Nov 30th, 2011
      08-19-2012 01:38 PM #21
      Quote Originally Posted by jaredaggie View Post
      Jared
      Doors unlocked? Without doors unlocked you can only talk to some but not all modules.
    22. n00b
      Jul 1st, 2012
      Aggieland, Texas
      08-19-2012 05:58 PM #22
      Good question, went back and verified all doors were unlocked. It did however not allow access to 09 at all with the doors locked. No luck on this tip though. Thanks for trying.
    23. n00b
      Feb 18th, 2014
      Algeria
      2013 US VW PASSAT B7 Confort line, 103 Kw TDI Bluemotion
      02-18-2014 05:32 AM #23
      Hello,
      If the same sensor for autolights is used for the rain sensor (i'm not sure about it), then:
      There are two diodes in the rain sensor, an emitting one, and a receiving one.
      The autolight needs only a working receiving diode (for "measuring" ammount of light), the emitting diode is not needed in this case.
      The rain sensor need both working. To check the emitting diode, you can point a camera to the diode, you shoul be able to "see" the light through it (you must be in a dark place of course).
      You can check your camera by pointing to it a known working TV IR remote control.
      I will check mine today.
    24. Member
      Jun 17th, 2011
      Kirkland, WA
      2011 Golf TDI 4-Dr| DSG | Graphite Blue
      02-18-2014 04:02 PM #24
      I read somewhere that for 2013 and on, the rain sensor is not being installed on anything but SEL trim levels. SE's and below are out of luck. That may be the problem if yours isn't an SEL.
      Mk7 GTI 2 dr SE | Pure White | DSG | Performance Package
    25. Junior Member scirocco1800's Avatar
      Dec 14th, 2006
      PNW
      1992 B3 Syncro TDI, 1983 GTI, 1972 VW Sundial Camper, 1962 Type 1 Custom
      03-03-2014 06:30 PM #25
      Thought I'd shed some info:
      The RSL sensor is NOT the same sensor that is used for the Auto Headlights on the B7 Passats. The "Sun Sensor" for the Headlights is the hump the size of a quarter located in the top-center of the dash. The sensor at the base of the mirror assembly is for the rain functions only.
      I've yet to confirm it but I have a suspicion that despite not having the function "officially" in the S and SE trims, that the sensor is still there and would only need to be activated via coding for the auto-wipers to work.
