VWVortex.com - I think I have the dreaded Dual Mass Flywheel rattle...
    Results 1 to 20 of 20
    Thread: I think I have the dreaded Dual Mass Flywheel rattle...
    1. Member mabbonizio186's Avatar
      Oct 14th, 2006
      2015 VW, 2012 VW, 1982 MB, 1954 MB
      08-04-2012 02:11 AM #1
      Hi Guys to make this simple : 2012 Golf 2.5 5MT 2,600 miles.
      From the first time I pulled in my driveway with my car (after an hours drive home from the dealer) I noticed that when the clutch was let out in neutral the trans made a "marbles in a can" rattling sound. And then a similar whooshing noise in reverse, 1st, and second gear at low speeds.
      Took the car to my dealer where the tech said it was normal bearing play in the trans causing noise.
      (my past car was a 98 jetta 5 speed that I drove for 100k miles) - Never made a noise like this.
      So I'm taking the car in soon for my courtesy check ( within the first 3 months of ownership) and I'm nervous about how to approach this. I can post a video if need be. I am pretty positive the noise is not normal as it gets louder as the car has driven and is warmed up. It is most audible by the driver side wheel with the clutch let out and in neutral. Push the clutch in and all is quiet.
    2. Member itskohler's Avatar
      Jan 7th, 2011
      Jacksonville, FL/Dallas, TX
      2012 Jetta, 2008 Jetta RIP
      08-04-2012 11:08 AM #2
      A vid would help.
    3. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-04-2012 03:35 PM #3
      Here's a video of the noise. I placed my phone on the driver side wheel. When the clutch is let out you'll here a click and then a metallic chirping noise. When it's pushed in you can only here the motor, bringing it to another dealer monday.
      - Mike
    4. Member anteramk5jetta's Avatar
      Sep 11th, 2011
      Salisbury township/Allentown, PA
      2009 Volkswagen Jetta SE 2.5L, 1995 Ford F-150 Eddie Bauer edition 5.8L
      08-04-2012 08:19 PM #4
      Mine makes the same noise, which is just the internals of the transmission rotating and is normal. I work for a trans shop and had the owner and his dad listen to it and check it out, just the way they have the clearances set inside
    5. Member Justin14's Avatar
      Jan 7th, 2012
      USA
      2012 Golf 2.5 manual
      08-04-2012 11:47 PM #5
      I just went out to my new 2012 golf with 312 miles on it and listened with the clutch in and clutch out. I never heard anything unless I let the clutch out fast, then I just heard it engage. So its for sure abnormal, imo.
      good luck man
    6. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-06-2012 09:34 AM #6
      Just a follow up incase anyone has a similar noise:
      Brought the car to a different dealer who has a MUCH better reputation than the original one I went to. As soon as the tech heard it he said they would replace the clutch assembly. Waiting for a call from them to set everything up next week.
    7. Member eatrach's Avatar
      May 13th, 2004
      Upland
      '09 VW Jetta 2.5L auto, 2016 Golf Sportswagon SE, 2016 BMW X5 3.5 S drive
      08-06-2012 12:10 PM #7
      yeah that sound is not normal. Good thing you found a different dealer with a better reputation.
    8. Guest pete@blackforest's Avatar
      Aug 18th, 2011
      Raleigh, NC
      VW/Audi/BMW
      08-06-2012 01:47 PM #8
      My stock clutch assembly became audible after stiffer mounts were installed.
      I drove tens of thousands of miles that way without issue.
      Now a lightweight flywheel is in there and it loves to chatter.
      Some noise would be normal, but if your tech suggests it be replaced then I would follow that recommendation.
    9. Member TylerO28's Avatar
      Jul 7th, 2008
      Mill Creek, WA
      '08 2.5Turbo Rabbit
      08-06-2012 01:54 PM #9
      Get a single mass flywheel. Clutchmasters clutch kit its phenomenal, Pete is correct though chatter is there for sure, but you're getting so much more reliability
      Sent from the bottomless pits of HELL!
      god i love my car. it may not be fast, but it's crazy fun!
      C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
    10. Member TylerO28's Avatar
      Jul 7th, 2008
      Mill Creek, WA
      '08 2.5Turbo Rabbit
      08-06-2012 01:58 PM #10
      My transmission just blew up with the beginning signs sounding like this! Its the Trans input shaft play that then can turn to grenade style explosions
    11. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-07-2012 11:13 AM #11
      I'm really hoping the dealer will be able to fix it once and for all. If its just a little noisy and wont affect anything for the life of the car than I can live with it. Must not be THAT common of a problem if so few people replied..
    12. Member TylerO28's Avatar
      Jul 7th, 2008
      Mill Creek, WA
      '08 2.5Turbo Rabbit
      08-07-2012 04:05 PM #12
      I thought my throw out was bad for a while. Once i turbo'd my car,i replaced the clutch and flywheel.new throw out was included. The problem didn't go away.turns out it was my input shaft and 3rd gear that were going out slowly
      Sounds innocent...but you might be getting closer to this than you might realize
    13. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-07-2012 04:35 PM #13
      thats a bit scary.. although i have the power train warranty for like 5 years and 50k so im not super worried about the trans failing... VW will just have to replace it.
    14. Member TylerO28's Avatar
      Jul 7th, 2008
      Mill Creek, WA
      '08 2.5Turbo Rabbit
      08-07-2012 06:31 PM #14
      And give you a loaner for 3 weeks.my friend had his go.they didn't feel like ordering the Trans for a week lol
    15. Member
      Jan 11th, 2012
      El Segundo, CA
      2012 VW Golf 2.5l
      08-09-2012 01:12 AM #15
      Just watched the OPs vid a few times and then compared it to my car.
      2012 6400 miles.
      Mine is pretty similar. Definitely can hear more machinery rotating when the clutch pedal isn't pressed.
      Not quite as loud... But then again my head wasn't in the wheel well.
    16. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-14-2012 11:01 AM #16
      Picking my Golf up today from the VW dealer who replaced the clutch assembly. Will post later to let everyone know if the noise is gone.
    17. Member
      Jan 11th, 2012
      El Segundo, CA
      2012 VW Golf 2.5l
      08-15-2012 01:00 AM #17
      Did they mention the cause or reason for it to sound the way it did or was it just defective?
      Did they install a new flywheel as well?
      Looking forward to your update .
    18. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-15-2012 10:41 AM #18
      After picking my car up from the Vw dealer yesterday I drove it 100 miles to my beach house. As of now the noise is gone! The trans is silent in neutral. The dealer gave me zero problems and replaced the clutch, flywheel, throw out bearing and all the stretch bolts in one day. The total bill of parts came to about $2100 paid by Vw and they even gave me a loaner for the day. I think this is a more common issue than we realize as the service guy told me they had replaced a few clutches in new cars. I'd say if you have this noise bring your car in to the dealer and if they give you a load of crap bring it to another dealer with a better rep. When I asked if any parts had obvious defects the tech said no other than that there was some surface rust on half of the clutch disk.
    19. 08-18-2012 10:47 PM #19
      Your dealer may have left a good impression with you, but VW will no doubt kick that claim. That noise is NORMAL. Until 2010 from about 2005 dual mass flywheels were used. Now, they use single mass flywheels for the 2.5 engine. This means more noise (gear rattle) which is normal. Yours will make noise again and don't worry about it.
      13 Jetta VI GLI
      12 Jetta SE SOLD
      Dual horn conversion
      Alarm retrofit
    20. Member mabbonizio186's Avatar
      Oct 14th, 2006
      08-18-2012 11:04 PM #20
      I agree that some noise is normal, however my clutch pedal was feeling strange, and there was an audible clicking/tapping inside the car that would change pitch if slight pressure was put on the clutch pedal. So while the flywheel rattle may be normal, something in their definitely needed to be fixed.. not to mention i'll use this dealership from now on since they did not just dismiss me.
