Who's good with Vag-com?
A check engine light came on in my wife's B5 passat 1.8t (weird, right
) with an emissions workshop warning on the display. So I get my buddy to scan it expecting something emissions related but the scan came up with nothing like that. I did get some pretty interesting fault codes and wanted to get some other peoples oppinions on whether I should do anything about them and some places to start. We reset the check engine light and so far it hasn't come back so we'll see if it was a hiccup or something bigger.
The car itself never had any hesitation in power or limit in revs or any noticable change in driving characteristics.
Here's a copy of the scan results:
Thursday,02,August,2012,10:41:56:08596
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 269520km/167471miles
Address 01: Engine Labels: 06B-906-018-AUG.clb
Part No: 4B0 906 018 BQ
Component: 1.8L R4/5VT G 0003
Coding: 16501
Shop #: WSC 03310
VCID: 71E25A2B3BB23B1
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 -
17947 - Clutch Pedal Switch (F36)
P1539 - 35-00 - Implausible Signal
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 00028
VCID: D3AE70A321EEE91
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 03 AIRBAG VW6 0003
Coding: 12339
Shop #: WSC 00028
VCID: 3776A4331556A51
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 920 B
Component: B5-KOMBIINSTR. VDO V26
Coding: 07245
Shop #: WSC 00000
VCID: 1D3A569B97AAEF1
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 00028
VCID: F0E4DF2FB0B8B29
No fault code found.
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 6W Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00028
VCID: 860899F7A23C8C9
Subsystem 1 - Part No: 1J1959801D
Component: 6W Tõrsteuerger. FS0002F
Subsystem 2 - Part No: 1J1959802E
Component: 6W Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811D
Component: 6W Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812D
Component: 6W Tõrsteuerger. HR0002r
1 Fault Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
End ---------------------------------------------------------------------
VCDS Release 11.11.3: SRI Reset
Control Module Part Number: 3B0 920 920 B Labels: 3B0-920-xx2-17.lbl
Component:B5-KOMBIINSTR. VDO V26 , Coding:07245
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status --- --- ---
40 Mileage since Service --- --- ---
41 Time since Service --- --- ---
42 Min Mileage to Service --- --- ---
43 Max Mileage to Service DIST x1000 15 ---
44 Max Time to Service --- --- ---
OBD DTCs erased
Thx in advance for any help.
