VWVortex.com - Prop Shaft Hanger Bearings?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 34
    Thread: Prop Shaft Hanger Bearings?
    1. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      East of the Mountains, WA
      77' Rabbit 16v, '98 A4 Avant, '07 A3 S-Line
      08-04-2012 05:41 PM #1
      Is there a source for these other than the dealer? I have a friend in the parts at one so I am having him look into them for me, but I read some older threads about there being an aftermarket source for quite a bit cheaper.
      Posted on the Yahoo syncro group as well as sent an email to the guy who used to post on here that had them. Any additional help, or even sources for them other than the dealer are hugely appreciated.
      Just pulled my drive line out today so I need to make sure I get them before next winter at the latest
    2. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      08-06-2012 09:11 PM #2
      No one has needed these anytime recently?
      Got a quote back from the dealer, retail on these is $270 ea
    3. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      08-06-2012 09:39 PM #3
      i got a custom set from Les. they're solid rubber mount, unlike the crappy oem ones.
    4. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      08-06-2012 09:47 PM #4
      I shot him an email on what I was able to find online, do you have any recent contact with him? Everything I have seen was over a year old from him, at least on these boards. He was selling them for about $100 a piece from the threads I saw, so that would save me a few hundred bucks haha
    5. 08-08-2012 06:36 AM #5
      I had heard to look at the Toyota Tundra hanger bearings.
      Not sure what would be required to make them fit,
      but they're $30 buy-it-now on ebay.
      -Dave
    6. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      08-08-2012 02:59 PM #6
      I have talked and researched this to death and there is no one that has successfully used different bearings to fit the syncro. It has been mentioned and talked about in countless threads and discussions, with the results always coming back negative. What you have posted is about as far as anyone gets, hey I hear these work and they are cheap, good luck
      The biggest thing is the bearing is probably not an un-common size, but the rubber housing for it is not close enough to anything to work without serious fabrication to bolt in. The stock setup on my syncro has lasted since the car was new in 92 so I don't have an issue paying for the new OEM bearings, was just hoping someone had found a viable solution in the past few years
      All the threads and info for these online is almost all 3+ years old, I did recieve a reply from Les, the guy who was making his own. He is busy with family life and is planning on doing another run of bearings, just no idea when he will get the time to make it happen. Just happy to hear he is not gone and there is at least a chance he will make another run in the future
    7. 08-09-2012 03:30 AM #7
      Did you ask the UK boys?
      http://www.vwsyncro.co.uk/
      -Dave
    8. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      08-09-2012 09:36 PM #8
      I read through a ton of threads on that site, and most of them are on the yahoo group
    9. Banned ellocolindo's Avatar
      Jan 14th, 2010
      08-15-2012 01:23 AM #9
      count me in for a set of these. the guy that sold me the sedan told me they had been replaced under 20000 kms ago. i put the car on the hoist at work; and they are done for. luckily i bought the car for a swap; not a daily.
      so i am in for a group buy?...
    10. Member squeeze's Avatar
      Sep 4th, 2004
      Vancouver, BC
      Jetta Syncro GT
      08-23-2012 11:24 AM #10
      I'm in for a set!!
      pm if u know where to get some!
    11. Member boner's Avatar
      May 18th, 2002
      Ottawa
      95 golf race car, 15 highlander
      08-27-2012 07:36 PM #11
      Quote Originally Posted by MrDave View Post
      -Dave
      anyone have any info on this? i popped my while doing some initial tuning of the racecar. don't care about needing to fab mounts, its a race car, not a show queen.... just looking for info on if it fits the shaft!
      thanks
    12. Member boner's Avatar
      May 18th, 2002
      Ottawa
      08-29-2012 10:11 AM #12
      Well, i found a $2.19 solution to my fried hanger bearing. In my case the bearing itself is fine, just the rubber around it died. Given that my car is a track only car, nvh is not a concern at all. So i made a new mount by welding mounting poi ts and reinforcement on to a 2" exhaust clamp. I took a blade and cut as much protruding rubber off the bearing and it comes out to roughly 2-1/8" od, the 2" clamp has an od of roughly 2-1/8".... There is some wiggle room as a result of the remaining rubber on the bearing but it clamps down quite well. When the car car' s put away in the fall, i can see me doin the same to the front bearing as well...
      Just an fyi for those who don't feel like giving stupid money ($400) to the dealer for more crappy rubber....
    13. Banned ellocolindo's Avatar
      Jan 14th, 2010
      08-29-2012 10:28 AM #13
      Can you post or email some pictures? I work at a truck shop so i can visualize the u-clam style exhaust clamp you are talking about. It is the cutting of rubber that throws me off a bit.
    14. Member boner's Avatar
      May 18th, 2002
      Ottawa
      08-29-2012 11:16 AM #14
      Ask and ye shall receive. Was thinkin bout making a thread but really, it's not a big thing in the end. And my part is too fugly to post up here :p
      Grrr, stupid pic host fail will fix tonight
    15. Banned ellocolindo's Avatar
      Jan 14th, 2010
      08-29-2012 11:30 AM #15
      I am in hamilton. I will see if i can have transaxle look at it or another driveline shop come up with a more standarized aproach to it.
    16. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      S1 Storm 20vSC-AWD, 93 Corrado VR6
      10-29-2012 11:58 PM #16
      I have yet to run these yet, but I used E30 hanger bearings. The center metal sleeve that the bearing sits in needs to be trimmed down a bit so the cups on the end of the prop shaft can bolt down all the way.
      I should also mention that since my Syncro swap is custom, I fitted the body tabs to the e30 parts. I think the spacing was really close to stock though so they in theory should work in a factory application.
      I know that toy_vw used the tundra hanger bearings for his scirocco2 syncro swap if that helps anyone.
    17. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      10-30-2012 10:19 PM #17
      Can I put that in mine and let you know if it works?
    18. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      10-31-2012 03:10 AM #18
      Sure, you know where my pile of parts are
    19. Member boner's Avatar
      May 18th, 2002
      Ottawa
      10-31-2012 11:55 AM #19
      Ohh, i like that. Just checked online and i can get them for under $40
    20. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      11-28-2012 03:14 PM #20
      Matt, are all the e30 bearings the same? I'm thinking of giving them a try.
    21. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      11-28-2012 09:18 PM #21
      Quote Originally Posted by -RalleyTuned- View Post
      Most likely not. I will check and see which I used and let you know though.
    22. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      12-26-2012 03:30 PM #22
      Hey matt, any news?
      had about 6' of snow in the last week, it got a little interesting sometimes
    23. Member rte7x9's Avatar
      Jun 11th, 2008
      Fenton, MO
      02-08-2013 04:21 PM #23
      Anyone know the shaft diameter/inner diameter of the bearing?
      87 GTI - Syncro 16v - Stage Rally Build!
      86 GTI - Digi1 16v - RallyX Machine!
      91 BMW e30 - Daily Driver/Hoonmobile!
    24. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      03-12-2013 02:47 AM #24
      I effed up and pressed one of them on wrong, I can measure when I pull it off again.
    25. Member rte7x9's Avatar
      Jun 11th, 2008
      Fenton, MO
      03-24-2013 05:36 AM #25
      Disassembled my prop shaft today, both bearings have a 30mm inner race (1.180") and are 13mm deep (.512") which is identical to the BMW E30 center driveshaft bearing. If you're swapping into a non-Syncro car I would highly suggest using the E30 bearings since they're $13 USD.
      The part numbers on the stock bearings are 191 521 352 and 191 521 351. I can't find those part numbers listed anywhere to even get a price. I'm sure they're not cheap.
