Page 4 of 24 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 809
Thread: Wtf happened to my front wheels!!!
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:00 AM #106
    Quote Originally Posted by Robski92 View Post
    Take it to a shop. No really.
    I know I Can't go far with te wheels all out. And I'm having a hard time raising the rears to be able to drive
    i want my Dub lower than my self esteem!
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:07 AM #107
    Think it old be the subframe or the control arms?
  3. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-06-2012 12:08 AM #108
    Quote Originally Posted by Reptar210 View Post
    How are you having issues?
    Jack up the rear. (Use jack stands unless you have a death wish)
    Get under the car.
    Spin the collars.
    Lower jack.
    Done.
    Quote Originally Posted by pentaxshooter View Post
    Ant's car doesn't actually move. He just drives a rollback as a daily. A GTI happens to reside on it.
    Maintenance is paramount.
    Corn Status l Podi l Gonzo GTT l ORT
  4. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-06-2012 12:10 AM #109
    Why would it be either if the wheel was not like that before? Use logical thinking. Positive camber came after the Ultimos and ball joints, therefore one of the two has to be the issue.
    Go grab your old ball joint and swap it in. See if that makes a difference.
  5. Member bryanboley's Avatar
    Nov 23rd, 2010
    03 Wolfsburg Jetta
    08-06-2012 12:13 AM #110
    Ant you so smart.
    Quote Originally Posted by Gunslinger7 View Post
    I usually just use placental tissue to affix my coilpacks when they get loose.
    http://forums.vwvortex.com/showthrea...wnpipe-etc.%29
    ^^Buy my sh!t up there^^
  6. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:15 AM #111
    Read what I have been saying silly, it WAS like that before, but with 15x6.5 you not notice it as much Asa 18x9
  7. Member euro+tuner's Avatar
    Jan 31st, 2007
    Carlisle, Pa
    Bagged Econobox
    08-06-2012 12:15 AM #112
    How did the bushing and bearing looking when you installed the coils? Regardless, YES that bushing is destroyed, replace the strut bushing and bearing!
    And does this look fuhkkked up?
    I lurk l IG: evans89411 l Flickr
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:16 AM #113
    Quote Originally Posted by euro+tuner View Post
    How did the bushing and bearing looking when you installed the coils? Regardless, yes that bushing is destroyed, replace the strut bushing and bearing!
    Bearings are brand new, would vw have them
  9. Member bryanboley's Avatar
    Nov 23rd, 2010
    03 Wolfsburg Jetta
    08-06-2012 12:16 AM #114
    well i would advise fixing the problem before installing new ones
  10. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:16 AM #115
    Quote Originally Posted by .Ant View Post
    Get under the car.
    Spin the collars.
    Lower jack.
    Done.
    I think thy are maxed out? Idk... They are fuhking tightttt
  11. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-06-2012 12:17 AM #116
    Get under your car and see if your subframe is shifted one way or another. I doubt it would cause that much of an issue though. Has the car ever been in an accident?
  12. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-06-2012 12:18 AM #117
    You may as well post how you installed them as well.
  13. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:19 AM #118
    But both sides are like this, and the guy I got it from said no, it's a salvaged title from axle coming off
  14. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:21 AM #119
    Spun to the top. Threads re t the bottom, rears are pretty self explanatory
  15. Member euro+tuner's Avatar
    Jan 31st, 2007
    Carlisle, Pa
    Bagged Econobox
    08-06-2012 12:21 AM #120
    Bushing also?
    Quote Originally Posted by bryanboley View Post
    In the top picture the opening for the strut looks off center in the bushing I quoted. Just curious if he reused the bushing from his previous suspension.
  16. Member GaugeDoisher's Avatar
    Oct 24th, 2009
    Dallas, Tx
    1964 vw bug, 2003 24v vr6 GTI
    08-06-2012 12:21 AM #121
    Hasssss to be ball joints haha
    My build!
    Instagram: @gaugedoisher <---- follow it b!tches
  17. Member bryanboley's Avatar
    Nov 23rd, 2010
    03 Wolfsburg Jetta
    08-06-2012 12:23 AM #122
    Quote Originally Posted by GaugeDoisher View Post
    he right doe
  18. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:23 AM #123
    Bushing also?
    No bushings are reused
  19. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:24 AM #124
    But before I changed them it had te same problem
  20. Member Chris Anderson's Avatar
    Jun 17th, 2012
    Fredericksburg, VA
    bagged mk4 jetta
    08-06-2012 12:26 AM #125
    so you bought the car with positive camber?
    Instagram: @chris_anderson93
  21. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:27 AM #126
    Quote Originally Posted by Chris Anderson View Post
    Not very noticeable with the 15x6.5s, when I put my long watches on you can notice it but not as ad as the 18x9s
  22. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:28 AM #127
    Long beaches not watches hahh
  23. Member Chris Anderson's Avatar
    Jun 17th, 2012
    Fredericksburg, VA
    bagged mk4 jetta
    08-06-2012 12:35 AM #128
    so we know its not the ultimo struts or ball joints since it happened on stock suspension and before you replaced the ball joints...
  24. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 12:46 AM #129
    Exactly why I'm thinking it's the sub frame, lower control arms or the tie rods somehow... Maybe even then hub???? Where the strut goes in
  25. Member oakdub's Avatar
    Feb 27th, 2011
    Oakville, Ontario
    99.5 flash red race car
    08-06-2012 12:50 AM #130
    And this Is how I have it assembled it.
  26. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 01:05 AM #131
    Quote Originally Posted by oakdub View Post
    Did you find the missing link lol
  27. Junior Member jefevw'00's Avatar
    Oct 19th, 2009
    757 VA
    e30 bmw 325e rip 2000 jetta 2.0Lives strong
    08-06-2012 01:06 AM #132
    i could be wrong but are axles different lengths between engine codes? as in 2.0 to 1.8? if so maybe the wrong length axle was used? i actually read
    8v society #14
  28. Member GTIDamien_407's Avatar
    Nov 23rd, 2008
    Burlington, Ontario
    2004 Jetta TDI Sport Edition, MK2 Golf Coupe, Red and Gold Rocket
    08-06-2012 01:07 AM #133
    seriously read this lol
    http://noahlh.com/car/coilover_howto/
    FS - OZ M-191 Center Cap - http://forums.vwvortex.com/showthrea...5#post77384355
    Diesel Dub Club #38 || Euro Style || MK2 Militia ||
  29. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 01:17 AM #134
    Quote Originally Posted by GTIDamien_407 View Post
    You must have only read page one. That piece as been taken out,blow after reading tat, should I not use that aluminum spacer?
  30. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 01:18 AM #135
    Quote Originally Posted by jefevw'00 View Post
    Hmm... Idk if they are any longer... I have. 1.8 if it helps lol.
  31. Member euro+tuner's Avatar
    Jan 31st, 2007
    Carlisle, Pa
    Bagged Econobox
    08-06-2012 01:18 AM #136
    Replace those also.
  32. Member Robertofields's Avatar
    Jul 11th, 2011
    Severn Maryland
    05 jetta, 89 cabby
    08-06-2012 01:38 AM #137
    That sucks lol.
    Quote Originally Posted by dopesauce View Post
    Are you high?
  33. Member das-yeti's Avatar
    Apr 20th, 2003
    savannah
    92 jetta, 04 R32
    08-06-2012 01:44 AM #138
    FYI #8 is the gold cone. Dont use the OEM as well.
    If that doesnt fix your camber, losen the three ball joint bolts and pull the bottom of the wheel out while tightening the bolts.
    This
    My fast has a Hitler stache!
  34. 08-06-2012 03:34 AM #139
    Looks like someone smashed your car into a curb previously, mine was exactly like that when i bought it. Your hub/spindle is bent.
  35. Member
    Feb 1st, 2012
    San Antonio Texas
    02 gti 20v
    08-06-2012 06:51 AM #140
    Quote Originally Posted by das-yeti View Post
    This
    Done already
