Why is this not fixed yet.![]()
#246
#248
Still not fixed?
There must be multiple parts to this movie. I am now waiting for the sequel.
Flawless.
#249
|| Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
|| Please don't PM me with offset questions, post in THIS THREAD instead ||
Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
#250
The fact that you haven't figured this out yet leads me to believe that you should never be working on a car.
#251
#252
Yea problem is still there took it to a shop the guy couldn't come up with a solution. Still waiting for my control arms. Anyone have any input on the idf camber adjustable control arms?
i want my Dub lower than my self esteem!
#253
Did you ever check the ball joints? and make sure they were on the right side?
#255
#256
#258
So why no positive camber in this picture from your other thread...??
http://forums.vwvortex.com/showthrea...-enough-camber
#259
is this still not fixed?holy sheet
#260
I play COD and such on the PC. Pwning a bunch of spoiled over weight 12 year olds while using an aim assist (360 & PS3) only to think your a pro afterwords is just....... meh'
Steam: http://steamcommunity.com/id/akrazyassho/
#261
I see positive camber.. Nowhere near as much as the pictures on pg.1 but maybe thats just me..
Syndicate________________________________TheChive _______________________________DriveWayBuilds
_____________________________________Follow Me @Kuncle
#263
Yea defenetly can't tell as bad, that is weird but yes the problem is still there, ecstuning is slacking on my shipment, I'm thinking of going up to austinveedub to pick up a subframe so I can roll that out. People are thinking the previous owner hit a curb or someone hit him, and he hit a curb
#264
#266
**** it. im in too...
#269
still there pretty bad, hard to tell through a rock camera. but even on long beaches its pretty noticable.
#270
Not hard to tell at all, that is utterly ridiculous. Have you put your stock suspension back in? That would rule out your struts entirely
#271
i can't even make sense of this situation any more.
#273
put a level to your wheel and measure the camber degree.
#274
still waiting on control arms ffs...
if that doesnt work than going to Austinveedub to pick up a sub frame. if that **** dont work.... anyone have a mark 4 front end they want to donate?![]()
#276
#277
#278
Run out and take a measurement of your strut towers, the center of one to the center of the other. I will get a measurement tonight and we can see if the strut towers are within spec or if they are pushed out due to an accident or something. Would be cheaper to check than just order a subframe. Also pictures of your subframe might help determine if it had been bent up at all
#279
Take the front wheels off and the brakes, try to get a picture looking from the front of the car at the spindles. Based on everything I've read and the pictures you posted, the ball joints should be fine, you seem to have figured out the correct order of the assembling the struts, and the control arms don't really look bent. From what I can remember looking at spindles, the arm that reaches out to where the strut mounts should be over 90 degrees to the rest of the spindle where the hub sits. Meaning, if the strut mounting arm looks perpendicular to the hub, it's bent.
My vote is spindled. Seen a car with a camber issue one side before, and that was the problem. Maybe the chances are slim that both sides got messed up, but any chance is still a chance.
I do coilover installs, retrofits, audio, fender rolling and other light maintenance in South Jersey. Eastwood fender roller for rent. PM me with questions
| 3076r | Unitronic 630 | Siemens 630cc | IE rods | OEM largeport IM | Custom 3" TBE | Southbend Stage 3+ | Hotchkis F&R sways |
#280
Your **** is ****ed dude.
Hope you can figure this out though![]()
