VWVortex.com - Question for the g60 Guru's
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 37
    Thread: Question for the g60 Guru's
    1. 08-04-2012 09:24 PM #1
      How do i get my g60 BBM stage 4 with 58mm pulley not to lean out?
    2. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat 07 3x White NB & 08 Yukon Denali XL to tow em
      08-04-2012 10:06 PM #2
      The lean out issue that can occur is:
      The #1 cylinder at the end of the intake starving at high boost. The cure is this:
      SR ported G60 stage 1 intake manifold, powder coated
      and
      Run the set up on your car by someone at TT, BBM or buy a chip from SNS and they'll figure out what you need as far as fueling and chip tuning
      http://snstuning.co.uk/g60.php
      and
      with that small of a pulley you'll need a standby g-lader to swap in every 6-12 mos while your charger gets rebuilt / inspected.
      !! opɐɹɹoɔ ǝɥʇ!!ƃuıʇɔǝdsǝɹ !!!
      !! odarroɔ ǝht gnitɔepser !!
    3. 08-05-2012 09:11 PM #3
      I already have that manifold from nyfam on my car. and have my fuel pressure set at 50lbs and still leans at the top or my rpms.
    4. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      08-05-2012 11:49 PM #4
      BEGI rising rate fpr - Forgot the key componet
    5. 08-06-2012 01:05 AM #5
      Pete I have the BBM adjustable FPR. SHould my Fuel Pressure be higher you think?
    6. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      08-06-2012 11:19 AM #6
      What injectors are you running? Sounds like you are running out of injector/fuel and the only way to get around that is larger injectors or higher fuel pressure. Both of which need need proper chip mapping or you will be fighting yourself. too rich down low to get ok up top, etc, etc... That is unless, you want to fiddle with a rising rate FPR, but that is all trial and error and wideband is a Must.
      Might be time to think about standalone if you want to push the envelope. Also, remember that the G60 ECU's MAP sensor is very limited (can only read up to 1 bar of boost), so you are already past what the ECU can interpret and the Map is just set to guess on what the Fuel needs are at full boost.
    7. 08-06-2012 06:58 PM #7
      i have 30lbs injectors. i noticed everytime i shift gears also in high rpms feels like the car falls flat on its face then starts to pull again...... like a hesitation thing. Any idea's what that can be? it also did it when i had a 68mm pulley on it. so i changed cap rotor vac lines plugs wires. 1 meter hose to the ecu. and re set my timing to 6. replaced fuel filter and knock sensor but still doing that hesitation. Does anyone know what is the difference between the purple label ecu and the brown? im running the brown. Didnt know if that maybe had something to do with it.
    8. Member sdezego's Avatar
      Apr 23rd, 2004
      08-07-2012 12:49 AM #8
      W/o any wideband logs, it is all a guessing game.
      Do you have a Fuel Pressure gauge to see if you pump is giving up the ghost?
    9. 08-07-2012 11:41 AM #9
      My gauge is on the fuel rail. i guess i would have to go to a dyno and stand in place where i can see what its saying at WOT? but if it was fuel pump figured it would just give up. Not do what its doing to me. Wide open throttle first gear good. when i switch to second WOT then it feels like something is holding me back then starts to pick power up again. WEIRD
    10. Member Pete O. Arguelles's Avatar
      Jul 5th, 2000
      Houston area
      92 GTI 16V Aw,92 GTI 16V Tred,90 G60 DS Corrado,337,92 SLC SS Corrado
      08-08-2012 01:08 PM #10
      My G60 does the same thing with a 68mm pulley. First gear is usless I feel it there also but it's really short revs very quick, when I get into second thats where I feel it the most. I have not pushed the car too much after that fearing a lean condition. I need a LM-2. I was thinking the ISV is opening and closing trying to control boost but I really don't know. I have a rebuilt G-ladder with no ISV-re-reoute pushing 9lbs. of boost.
      Car feels nice and strong with a little more boost and that surgeing gone it would be a really quick car.
      I'm wrighting it up here
      http://www.epmtuned.com/id269.html
      I have avoided using a smaller pulley for this reason and holding back from installing a Lysholm supercharger I have. Also I have been avoiding raising the fuel pressure too much to prevent puddling and ruin the engine. Currently using a 3.5 FPR.
    11. Member Pete O. Arguelles's Avatar
      Jul 5th, 2000
      Houston area
      08-08-2012 01:52 PM #11
      Would this help from BARTEK tuning?
      http://www.bar-tek-tuning.com/ladedr...er+map+kpa.htm
    12. Member Pete O. Arguelles's Avatar
      Jul 5th, 2000
      Houston area
      08-08-2012 02:04 PM #12
      Quote Originally Posted by sdezego View Post
      I thought that also but I have a brand new the updated Bosch pump in the car. By the way my G60 is a single pump car. Unless this pump is not providing enough fuel pressure I need a FPR in the car. I will be tigging up a BBM rail with this provision done one already just not for his car.
    13. Member sdezego's Avatar
      Apr 23rd, 2004
      08-08-2012 05:09 PM #13
      You have the same setup and the OP? 30# injectors @ 3.5 and BBM chip? Might want to start a different thread if not to prevent a LOT of confusion.
      I can tell you that years ago, I maxed out stock injectors early on after going Cam and 68mm pulley, ported charger, etc. 30# @ 3bar gives you only slightly more than stock injectors @ 3.5 bar. 30# @3.5 (with the correct chip mapping) should give you enough fuel for most setups with 65mm+. Small pulley than that and you are chasing a dream and either need a rising rate FPR, or larger injectors and upgraded MAP sensor with corresponding chip, or all of the above.
      If you guys insist on staying with Digi vs standalone and push the limits. You really need to get on the threads regarding programming your own chip via TunerPro and the .XDF quite a few people have been working on over the years. IMO of course...
    14. Member Pete O. Arguelles's Avatar
      Jul 5th, 2000
      Houston area
      08-08-2012 06:34 PM #14
      My set up is stock injectors, 3.5 bosch FPReg, BBM STG3 chip, Stock cam.
      I'm not new to G60's but very new to tuning. I have made my G60's look good IMO now i'm trying to make them faster. Would love to work with the stock digi 1 but not limited to it and would go standalone.
    15. 08-09-2012 12:20 PM #15
      Ive done about everything and changed everything but still dont know where the hesitation comes from. Im currently running bbm stage 4 kit ported head, ported manifold 68mm pulley tt header front mount intercooler rebuilt charger with mini port isv re route. changed every vacum hose fuel pump fuel filter cap rotor plugs wires etc. im out of idea's now.
      forgot im running bbm fpr have it set at 50 psi with 30lbs injectors
    16. Member sdezego's Avatar
      Apr 23rd, 2004
      08-09-2012 12:41 PM #16
      Quote Originally Posted by jeffs vw View Post
      What FP is your Chip programmed for? If you are running Higher than you will hit some very very spots down low (but may be fine up top). You need to get a wideband to see what is happening. You might also want to look at the Fuel Pressure during that time to see what is happening if anything (rule that out). Tape it to your Wiper LOL
    17. Member Pete O. Arguelles's Avatar
      Jul 5th, 2000
      Houston area
      08-09-2012 05:29 PM #17
      My car does the exact same thing although I don't have all the mods u do. I can tell you this at work we have a mile long straight away rd to get home. After the car has been parked for 12hrs. we get out on the rd and get on it, with a cool engine the hesitation or surge is not there or is very little unnoticeable. Car feels twice as strong then. I know a cool engine produces more power even more when the air is dry and cool. But without the surge being there it revs so nice feels very strong.
    18. 08-09-2012 07:20 PM #18
      i might need to do that. wideband and look at fuel pressure underload. im eventually gonna figure it out. or keep asking questions
    19. Member g60301's Avatar
      Aug 4th, 2011
      Maryland
      90' Corrado m62
      08-10-2012 01:49 AM #19
      Never seen a brown ecu? My original one was white. I'm running a purple ecu now. Could the brown ecu be specific for California's smog?
    20. 08-11-2012 03:35 AM #20
      Quote Originally Posted by g60301 View Post
      Oops.... i mean White label ecu i have. is there a difference between white and purple? i have one of those also.
    21. Member Pete O. Arguelles's Avatar
      Jul 5th, 2000
      Houston area
      08-11-2012 04:46 PM #21
      p[weuitgjocn o2g[12v
    22. 08-14-2012 08:30 PM #22
      well after all the Shiiiit i went thru changing. i think i got it. it hasnt hesitated since. I replaced the positive wire thats on the alternator and the blue wire also. and my ECU hose was 33 inches long not 1 meter exactly. and hasnt done it since. So i slapped my 62mm pulley and seems like its pullying good. just my Narrow band showing lean in the top with 51 psi on my fuel pressure gauge. not sure if i should add more? I thought we were suppose to run 3.5 bars?
    23. Member sdezego's Avatar
      Apr 23rd, 2004
      08-15-2012 12:01 AM #23
      3.5 bar should be when the FPR is at ATM (vac line pinched or open). Fuel pressure under boost should be 3.5 + boost. So 1 bar of boost, Fuel Pressure should be 4.5 bar in this case. If it is not, then your FPR is not working or connected correctly.
    24. 08-15-2012 01:56 AM #24
      so 3.5 bar is 51.45 psi this is what i have on my gauge while hose plugged into my bahn brenner adjustable FPR at idle.
      So your saying i should raise it up to 4.5 which will equal to 66.15 psi while at idle plugged in or do you mean while unplugged?
      Sorry for being confused just trying to get my car to not lean out so much
    25. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      1992 Corrado ABA-T and MS3-Pro powered, 84 Honda V65 Sabre
      08-15-2012 07:56 AM #25
      Then throw the DIGI junk ECU in the trash where it belongs and go standalone.
      The Professor
      Melbourne, FL
      92 Corrado OBD2 ABA-T (BW EFR 6258) Powered by MS3Pro
      Linfert Performance: The Megasquirt guy in central Florida Like my Facebook page....
      Sandy Linfert 11/4/1991 - 5/13/2013
