Results 1 to 8 of 8
Thread: How do I clean Throttle-body on 90 cabby :)
  1. Member cabriogal11's Avatar
    Jun 16th, 2006
    The Hood -
    1990 Cabriolet 1.8
    08-05-2012 11:19 AM #1
    Hi everyone I was told to clean my throttle-body on my 90 cabrio - can i use carb cleaner - once i unhook it all? Its really running rough
    Thanks
  2. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    08-05-2012 05:21 PM #2
    I use SeaFoam Motor Treatment, I use a aquarium air valve and vinyl tubing and insert it at the Fuel pressure regulator hose attachment to the throttle body. The valve is to meter it in slowly.
    It produces Smoke out the wazoo. 90's are Cabbies, Cabby, or Cabriolets, Cabrio is a totally different car... (I know I am anal that way.).
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  3. Member cabriogal11's Avatar
    Jun 16th, 2006
    The Hood -
    1990 Cabriolet 1.8
    08-05-2012 06:40 PM #3
    Quote Originally Posted by briano1234 View Post
    Opps I called it a cabby then a cabrio ikes - I should know better this is my third one tsk tsk
    I mean how do I disconnect it?
  4. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    08-05-2012 06:51 PM #4
    Quote Originally Posted by cabriogal11 View Post
    Grab the end of the hose and pull it off the throttle body.
  5. Member cabriogal11's Avatar
    Jun 16th, 2006
    The Hood -
    1990 Cabriolet 1.8
    08-05-2012 06:57 PM #5
    There's many obstacles? is it as simple as removing the silver band? or? sorry noob here first time doing this
  6. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    08-05-2012 07:20 PM #6
    On the back side of the throttle (passenger side) you will see a vacuum hose that goes down to a gold anodized device, that is the Fuel pressure Regulator.
    It is the Clear hose in the Picture at the back of the throttle body Pull it off the nipple of the throttle body. Insert your hose there, then into the Seafoam can. Or you can Spray Carb cleaner in that hole too. You will have to slightly increase the rpm, and have your car half out of your garage as you will be killing tons of Mosquito's throughout your neighborhood.
    You will also find out if your exhaust manifold is cracked.. as more smoke will come out the manifold than the tail pipe.
  7. Member cabriogal11's Avatar
    Jun 16th, 2006
    The Hood -
    1990 Cabriolet 1.8
    08-06-2012 11:37 AM #7
    Thanks for the photo explanation i also meant if I wanted to clean the intake manifold on the 90 cabby - there are way to many things attached/
  8. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    08-06-2012 04:57 PM #8
    Naw it just looks that way to fool the confused.
    see: http://volkswagenownersclub.com/vw/s...t.-90-93-Cabby.
    I shows you how to remove most of the crap to change a valve cover gasket.
