1984 Rabbit GTI for sale.
Clean title, smog done, fresh plates and registration.
Black color, 5 speed manual transmission.
Car runs & drives. You can drive it home!
155k miles on the body, ~80k miles on the engine. Got the car with blown engine and swapped it with a good working one.
Before putting in the new engine, all the gaskets around the engine were changed, $300 worth of new gaskets and seals from autohausaz.com: exhaust, intake, waterpump, every small o-ring and gasket, new timing belt, new tensioner, new front & rear crank seals, new injector seals, brand new clutch installed.
New brakes, axle boots changes, one front control arm replaced.
It has bilstein adjustable suspension.
Neuspeed throttle body, front upper strut bar, lower tie bar, rear strut bar.
It has front round light conversion, straight body, no rust, original paint, original wheels.
No A/C, it needs interior work, it has Recaro seats, dash has cracks in it, does not have rear seats, previous owner had a custom material covered plywood installed in place.
Price: $2600
I would consider trades for W202 body type Mercedes C230 or C280 ONLY between 1998-2000.
