Results 1 to 4 of 4
Thread: control arm & axle length
  1. Member Das_Boost's Avatar
    Sep 25th, 2004
    Central OH
    93 Wagon / 93 Corrado
    08-05-2012 12:21 PM #1
    i know that most parts are interchangeable between mk2, 3, Corrado, B3, and 4 platforms, and that certain ones are longer / shorter than others depending on platform and engine options...
    with this being said, i am looking for more specific data; specifically how much shorter the mk3 plus suspension is compared to the B3/4. i thought i read somewhere that it was 9mm difference?
    and if its only 9mm i know the control arms and axles will need to be swapped, but the tie rods should be able to compensate by screwing in further? anyone done this?
    thanks in advance!
    Quote Originally Posted by Torsten View Post
    Quote Originally Posted by dapucker1 View Post
    bbs suck
    only if you dont have them
    Quote Originally Posted by Joel Goodson View Post
    Buy wheels that fit. Its not hard. Well, to some it is.
    Quote Originally Posted by steveo27 View Post
    in soviet russia, wheel widens you
  2. Member max302's Avatar
    Apr 7th, 2010
    TR, QC
    '96 B4V VR6
    08-05-2012 01:17 PM #2
    I thought the MK3 plus suspension was exactly like the B3-B4 stuff, wider and all.
    I can probably get some measurements on the base MK3 stuff on Wednesday while I'm on a parts run.
  3. Banned ellocolindo's Avatar
    Jan 14th, 2010
    08-05-2012 02:03 PM #3
    if it helps i have technical drawing s of the b3 car with measurments of track; hight and all...
  4. Member Das_Boost's Avatar
    Sep 25th, 2004
    Central OH
    08-09-2012 08:17 PM #4
    after days of searching, i finally was able to find this, according to the Bentely:
    VR6 Passat track width = 1460/1422mm F/R
    VR6 mk3 track width = 1450/1432mm F/R
    Corrado track width = 1450/1432mm F/R
    ***EDIT***
    yet the 93 B3 brochure claims 58.4 [1483] / 56.2 [1427]
    bbs suck
