Results 1 to 12 of 12
Thread: removing stretched tires...
  1. 08-05-2012 02:18 PM #1
    im running some alphards on my tt with super streched tires. i wanted to change tires for some more meat but everyones telling me taking these tires off will RUIN the rims. what the hell am i supposed to do cut them off?!
    May 23rd, 2008
    Lewisville, TX
    2001 LZ7W 225 coupe; 2007 3.2 A3
    08-05-2012 03:29 PM #2
    Quote Originally Posted by aTTenzione View Post
    What??? there's a down side to stretched tires. say it isn't so.
    No really, i've never heard that and given the number of guys here that are running stretched, I'd think there'd be dozens of threads on damaged wheels due to removing stretched tires. I guess it is certainly possible but a quality tire shop should be able to remove them without damaging your rims.
    cheers.
    You don't own a TT, you support it: 2001 LZ7W coupe; REVO chip; Forge hoses and DV relo; MadMax DV; Modshack VTDA; BlueFlame Catback, OSIR corners, Forge bling, H&R, Bilsteins, DEFCON2, 986 seats, 18in OZ Vela II; OEM TTQS alcantara steering wheel, knob, ebrake; OEM: BBS RS IIs; roof rack; trunk rack; phone bracket; trunk mat; all weather floor mats; 4-piece Votex kit. My Mods here: http://public.fotki.com/TTQ2K2/. 2007 3.2 S-Line A3.
  3. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    08-05-2012 04:24 PM #3
    Might be onto something with having to cut them off. If they have a slight stretch it would not be a problem. But if its that scenester style childish stuff then there is a high likelihood that damage could be done as they try to pry the sidewall over the rim edge.
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  4. Member
    Mar 23rd, 2011
    Charlotte NC
    01 Jetta 1.8T; 01 TT 225Q
    08-05-2012 05:56 PM #4
    Might have better luck asking on the MkIV forum, or wheel & tire forum. Probably lots more people over there have gone for that look and can tell you from experience.
    May 23rd, 2008
    Lewisville, TX
    08-05-2012 08:40 PM #5
    Just occured to me that once the air is out, and the bead is broken, they are no longer stretched. therefore, the whole tire should move so that there is no issue when trying to pull them over the rim. no?
    bueller? bueller?
  6. Member trixx's Avatar
    Dec 23rd, 2002
    Toronto ON
    8NTTQC + MK3GTIVR6
    08-05-2012 11:12 PM #6
    i've been running stretched tires since 2004... on both my mk3s, mk1 and TT.
    17 or 18 different different sets of wheels and almost double that in sets of tires and i have never had issue taking tires off, and i mean zero problems. it's just like taking off any low profile tire if not easier.
    putting them on is the hard part, and the only real issue ever is getting the bead to seat, especially when running tires with stiff sidewalls, but that's nothing a can of ether or a cheetah can't handle.
    if your tire guy can't do it or is making excuses, find another tire guy
  7. Member 1.8Tbug's Avatar
    Jun 16th, 2008
    Michigan
    2001 Audi TT 225Q
    08-06-2012 12:01 AM #7
    i just dismounted mine on friday to get them powder coated no problem at all
  8. 08-06-2012 01:12 AM #8
    bueller? bueller?
    thats what i thought just taking all the air out first. we'll see.
  9. Member 1.8tipgls's Avatar
    Apr 13th, 2007
    NY
    01' S3, 01' TT 225 roadster w/Hardtop (sold), 03' Jetta (sold)
    08-06-2012 09:15 AM #9
    Quote Originally Posted by DeckManDubs View Post
    no, not at all
    as soon as the air is let out its just a regular tire on the rim which can be unistalled and installed like regular tire mounting, not a single thing different once the air is let out, tire comes off just like it always would
    DubCult _ Florio Special _ S3
  10. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    08-06-2012 02:10 PM #10
    Quote Originally Posted by 1.8tipgls View Post
    no, not at all
    good to know
  11. 08-07-2012 08:32 AM #11
    what Jimmy said, if your tire guy can't dismount them without damaging them, find a new tire guy plain and simple.
    p.s. Stretch will cause the car to explode though. just an fyi.
    May 23rd, 2008
    Lewisville, TX
    08-07-2012 09:31 AM #12
    Quote Originally Posted by Neb View Post
    True...but more importantly, it causes permanent shrinkage and limpness, so says recent study in journal of american medicine.
    cheers.
