Results 1 to 3 of 3
Thread: Need help activating Rain Sensing Wipers on 2012 Passat using VCDS
  1. 08-05-2012 03:24 PM #1
    I followed the instructions posted on other sites to activate Rain Sensing Wipers and auto window close. Everything seemed to work and I even went back and it saved the updated settings. The problem is that there is no option under "Convenience" to turn this feature on. I was advised by another forum member to run a full scan and post the results here to see if anyone can help.
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Sunday,05,August,2012,16:06:49:03076
    Chassis Type: 7N0
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 52
    56 62 72 77
    VIN: 1VWCN7A3XCC012849
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
    Part No SW: 03L 906 012 BP HW: 03L 907 309 S
    Component: R4 2,0L EDC H21 2158
    Revision: 71H21--- Serial number: 00000000000000
    Coding: 001D0012842400008000
    Shop #: WSC 09003 957 00200
    ASAM Dataset: EV_ECM20TDI01103L906012BP 004004
    ROD: EV_ECM20TDI01103L906012BP.rod
    VCID: 73CB028BDAAE091
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 054 C HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2806
    Revision: 05351113 Serial number: 00001106200677
    Coding: 0000020
    VCID: 160D1B1F219CBC9
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: C54BC0F5492300FCA31303E892220042270000
    VCID: 7BDB2AABFAFE411
    Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
    Part No SW: 5K0 959 434 B HW: 5K0 959 434 A
    Component: VWKESSYPQ35GP 085 0902
    Revision: 00085000 Serial number: 0149100923
    Coding: 130C0C
    ASAM Dataset: EV_KESSYPQ35G A02014
    ROD: EV_KESSYPQ35G_VW41.rod
    VCID: 3449C1979F204E9
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 561 907 044 D HW: 561 907 044 D
    Component: Climatronic H01 0102
    Revision: 00001001
    Coding: 0010001012
    ASAM Dataset: EV_ACClimaBHBVW411 A01001
    ROD: EV_ACClimaBHBVW411_VW41.rod
    VCID: 18111527E3888A9
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 087 Q HW: 5K0 937 087 Q
    Component: BCM PQ35 H+ 111 0147
    Revision: BL111001
    Coding: 6F200E1B802B2AD408880201360085480071008645A025F064 806000BC70
    VCID: 43AB924BC28EF91
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 310811 05 54 0403
    Coding: 06300A
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5C0 959 655 HW: 5C0 959 655
    Component: AirbagVW10G 013 0809
    Serial number: 003END09ASHV
    Coding: 00003548
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
    ROD: EV_AirbaVW10SMEVW360_VW41.rod
    VCID: EFC38EFB3686AD1
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
    Component: BF-Gewichtss. H10 0027
    Serial number: 6940000Y1100006NN40P
    Coding: 303252
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME7D2A6361ZZZ+
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME636D7360ZZZ
    Crash sensor for side airbag; rear driver side:
    Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Fahr.H H02 ----
    Serial number: 3516KSME19122412ZZZB
    Crash sensor for side airbag; rear passenger side:
    Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Beif.H H02 ----
    Serial number: 3526KSME666A4E12ZZZ$
    Crash sensor for front airbag; driver side:
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Fahr H02 ----
    Serial number: 3556LSME19266B10ZZZU
    Crash sensor for front airbag; passenger side:
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Beif H02 ----
    Serial number: 3566LSME7E1D6B10ZZZ5
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110720200450
    Coding: 001A140000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWSXS_VW41.rod
    VCID: 7DDF24B3ECEA4F1
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
    Component: E221__MFL-YVJ H06 0022
    Coding: E30000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 561 920 870 A HW: 561 920 870 A
    Component: KOMBI H07 0507
    Coding: 331E01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
    ROD: EV_Kombi_UDS_VDD_RM09_VW41.rod
    VCID: 1713161BEE96851
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 K HW: 1K0 907 951
    Component: J533 Gateway H40 1620
    Revision: H40 Serial number: 24081101291126
    Coding: 461000
    VCID: 3851F5A78B48AA9
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H07 0507
    Serial number:
    Coding: 000007
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
    VCID: EAF59FEF0D64489
    Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
    Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
    Component: ELV-PQ35 H20 0230
    Revision: 00000000 Serial number: 11000110729002
    Coding: 4900000000000000
    ASAM Dataset: EV_ELVMarquMPVW36X A01001
    ROD: EV_ELVMarquMPVW36X_VW41.rod
    VCID: 2E7DD3FF710C649
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7660667813
    Coding: 010000
    VCID: 297720E340E2031
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 3C8 035 684 E HW: 3C0 035 684 E
    Component: RNS-MID H59 3690
    Revision: AB001001 Serial number: VWZ6Z7L9220125
    Coding: 24090002010000A6000B
    Shop #: WSC 95243 999 19308
    ASAM Dataset: ------------------------- ------
    VCID: 2D7FD4F3740A1F1
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0525
    Revision: 13110009 Serial number: 0003137111
    Coding: 0404FD
    ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
    ROD: EV_TSGFPQ25BRFVW46X.rod
    VCID: DB9BCA2BD23E211
    Slave Driver:
    Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 3C0-959-70X-GEN4.CLB
    Component: J388__TSG_HL 004 4472
    Serial number: --------------------
    Coding: 800000
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 290 3201
    Revision: 00H20000
    Shop #: WSC 01357 011 00200
    VCID: 3449C19757204E9
    Address 47: Sound System (R12) Labels: None
    Part No HW: 3T0 035 456 B
    Component: KonzernAmp10K H06 0362
    Revision: -------- Serial number: BP225309712525
    ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
    ROD: EV_AudioVerst10KanalSTT3_VW41.rod
    VCID: 558F5C13341A771
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H40 1620
    Coding: 01030108
    VCID: EFC38EFB3E86AD1
    Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
    Component: J245 P05 FFD7 H07 0004
    Coding: 181100
    Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
    Component: Analoguhr 008 0002
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0525
    Revision: 15110009 Serial number: 0002600791
    Coding: 0404FC
    ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
    ROD: EV_TSGBPQ25BRFVW46X.rod
    VCID: DC99C937D730269
    Slave Passenger:
    Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 3C0-959-70X-GEN4.CLB
    Component: J389__TSG_HR 004 4472
    Coding: 800000
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007669739931
    Coding: 0A10040000010110
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA_VW41.rod
    VCID: 354FFC93945A571
    End ---------------------------------------------------------------------
    Apr 12th, 2010
    Lodz, Poland
    2011/Skoda/Superb 2 Combi 2.0 TDI 170
    08-05-2012 04:27 PM #2
    You need to enable Byte 4 Bit 5 & 6 as well in the 09 module.
  3. 08-05-2012 05:53 PM #3
    Great, thanks. That worked however the sunroof only closes halfway.
