I followed the instructions posted on other sites to activate Rain Sensing Wipers and auto window close. Everything seemed to work and I even went back and it saved the updated settings. The problem is that there is no option under "Convenience" to turn this feature on. I was advised by another forum member to run a full scan and post the results here to see if anyone can help.
VCDS Version: Release 11.11.3
Data version: 20120401
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 BP HW: 03L 907 309 S
Component: R4 2,0L EDC H21 2158
Revision: 71H21--- Serial number: 00000000000000
Coding: 001D0012842400008000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012BP 004004
ROD: EV_ECM20TDI01103L906012BP.rod
VCID: 73CB028BDAAE091
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 054 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2806
Revision: 05351113 Serial number: 00001106200677
Coding: 0000020
VCID: 160D1B1F219CBC9
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003END09ASHV
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360_VW41.rod
VCID: EFC38EFB3686AD1
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100006NN40P
Coding: 303252
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7D2A6361ZZZ+
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME636D7360ZZZ
Crash sensor for side airbag; rear driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME19122412ZZZB
Crash sensor for side airbag; rear passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME666A4E12ZZZ$
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME19266B10ZZZU
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME7E1D6B10ZZZ5
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110720200450
Coding: 001A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS_VW41.rod
VCID: 7DDF24B3ECEA4F1
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H06 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 870 A HW: 561 920 870 A
Component: KOMBI H07 0507
Coding: 331E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_VW41.rod
VCID: 1713161BEE96851
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 24081101291126
Coding: 461000
VCID: 3851F5A78B48AA9
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0507
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
VCID: EAF59FEF0D64489
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000110729002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW41.rod
VCID: 2E7DD3FF710C649
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660667813
Coding: 010000
VCID: 297720E340E2031
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C0 035 684 E
Component: RNS-MID H59 3690
Revision: AB001001 Serial number: VWZ6Z7L9220125
Coding: 24090002010000A6000B
Shop #: WSC 95243 999 19308
ASAM Dataset: ------------------------- ------
VCID: 2D7FD4F3740A1F1
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0003137111
Coding: 0404FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: DB9BCA2BD23E211
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 3C0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
