VWVortex.com - turbo manifold mounting help
    Results 1 to 18 of 18
    Thread: turbo manifold mounting help
      Jun 20th, 2010
      Philly
      2012 Dodge Charger, 91 Jetta VRT
      08-05-2012 06:20 PM #1
      this is the manifold i have SPA from blackforest industries.
      the turbo i have is the SPA 50 trim from blackforest
      I am not sure if the manifold should be installed so the turbo is on top or if it should be mounted so the turbo will be on top. just making sure the downpipe all work and i have room for piping etc...
      I think it needs to be installed so the turbo is on the bottom....
    2. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      08-05-2012 08:29 PM #2
      bottom mount turbo
      Jun 20th, 2010
      Philly
      08-05-2012 09:47 PM #3
      With turbo mounted with exhaust facing passenger or driver side
    4. 08-06-2012 11:22 AM #4
      Quote Originally Posted by Phillyninja View Post
      What chassis?
      Jun 20th, 2010
      Philly
      08-06-2012 11:48 AM #5
      95 jetta 4 door 2.0 ABA i learned how to clock the turbo and now I have another issue...
      any suggestions
    6. Member
      Jun 20th, 2010
      Philly
      08-06-2012 11:49 AM #6
      turbo is hitting the engine mount
    7. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      84 GTI/86 4000q/92 VR6T/07 Rabbit/12 GTI/97 F-350
      08-06-2012 12:01 PM #7
      Try temporarily tightening all the fasteners down so all the components are in their final locations, then see where you end up.
      Jun 20th, 2010
      Philly
      08-06-2012 01:24 PM #8
      still does not work, i think this will need to be a top mount turbo
    9. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      08-07-2012 01:36 PM #9
      How much of the mount bracket would need to be removed to clear the turbo? Some people have done that on Mk2 1.8T swaps.
    10. 08-07-2012 02:11 PM #10
      Must be a mk4 manifold... that mount isn't there on those engines iirc.
      Bumblebee Tuna
    11. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      08-07-2012 03:06 PM #11
      Quote Originally Posted by DieGTi View Post
      That is correct.
      Jun 20th, 2010
      Philly
      08-07-2012 08:08 PM #12
      what? the manifold is from blackforest for the ABA. and the mount is stock for this car.....so waht should I do? i have the turbo mounted on top right now and it seems itll work but the exhaust side is on the passenger side
    13. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      08-08-2012 09:41 AM #13
      Then I suggest you contact BFI for their opinion.
      And again:
      Quote Originally Posted by stealthmk1 View Post
    14. 03-20-2013 01:18 PM #14
      And again:
      hey guys, I'm Felipe, and i'm work at SPA Turbo in Brazil.
      the TMW08 is a bottom-mount manifold, but to use on the MkIII & below, is needed to use the SPA VW engine mount, it replaces the OE mount, clearing room for turbochargers up to .70 compressor housing.
      the MkIV doesn't need that mount.
      the PN for that mount is TMSPT06, hope that helped.
    15. Member
      Feb 13th, 2011
      Ft. Collins, CO
      '92 Passat G60 Syncro, '81 Scirocco, MkIV Jetta TDI
      03-20-2013 09:19 PM #15
      Well that just got a liitle more expensive...
    16. Member vwmaniac16vr6's Avatar
      Nov 17th, 2004
      North-west NJ 07838
      03-23-2013 08:11 AM #16
      its on amozon for $424
    17. 03-27-2013 05:17 PM #17
      that one is for BMW, the golf one is this one:
      http://www.spaturbo.com.br/loja/comp...02b68539cc.jpg
    18. Member therealvrt's Avatar
      Jul 21st, 2004
      ottawa ontario canada
      97 gti
      03-27-2013 06:18 PM #18
      Interesting.
      I have always thought about making a support arm back there for more clearance since the oem is hollow and take up space
