Results 1 to 6 of 6
Thread: no retract MkIV rear calipers
  1. 08-05-2012 08:00 PM #1
    I have run into this problem years ago, and do not remember the solution. Had to do pads on Mamma's '03 MkIV TDI, and I can NOT get the pistons to wind back in. If I go backwards, they will IMMEDIATELY wind out, but when I switch the reatchet and try to retract, they just sit there where I stopped and spin around.
    Kind of a panic as I have to leave for the bush tomorrow and she needs her car.
    Any suggestions?
  2. Member THP8VGTI's Avatar
    Dec 29th, 2002
    southern nh
    91 mk2 gti 16v, 94 Jetta VR
    08-05-2012 08:32 PM #2
    Apply pressure while turning?
  3. 08-05-2012 09:04 PM #3
    My winder is hand fed, and I think that might be the problem: need more pressure to stop the adjusting mechanism inside from spinning that direction.
    Thanks.
  4. 08-05-2012 11:21 PM #4
    OK, if anyone is interested: The deal is that you need to push back a wee bit of fluid before whatever is inside contacts whatever holds the thread still for clockwise loading, THEN it winds in very easily. Now I remember looking at the tool long ago and not liking the idea of continually putting pressure on the threads.
  5. Member osbornsm's Avatar
    May 7th, 2004
    Elgin, IL
    2004 VW .:R32
    08-06-2012 02:21 PM #5
    Push in as much as it'll take... 1/8" prolly.
    Turn fully 1-2 times, take up slack (push again)
    Repeat as needed.
  6. Member THP8VGTI's Avatar
    Dec 29th, 2002
    southern nh
    08-06-2012 08:54 PM #6
    Auto Zone or other parts stores may have the tool for rental. I work in an undercar shop and have used mine i dont know how many times with no problem. Just slowly put the pressure on it. Like someone else said turn a little add pressure, and keep doing that. As long as they turn your good. Just watch the boots that they dont twist on the piistons and rip
