Results 1 to 6 of 6
Thread: Just got my Vag-Com, first scan inside
  1. 08-05-2012 08:39 PM #1
    Just downloaded/installed the latest version software from Ross-Tech. 2008 Passat 2.0t / 6MT. APR Stage 1 tuned.
    I know about the parking brake fault- have a dash switch on the way that should take care of that. Dealer recently did an update on the immobilizer and had previously done something they call an "overlay" on the steering interlock. What other problems am I looking at here:
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Sunday,05,August,2012,19:36:20:29804
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
    VIN: WVWUK73C28E071144 Mileage: 108950km/67698miles
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Sporadic communication error 1000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    1C-Position Sensing -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: Sporadic communication error 1000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0020
    Revision: 5BH16--- Serial number: VWZCZ000000000
    Coding: 0404010A18070160
    Shop #: WSC 05314 000 00000
    VCID: 306FA98EA338729
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
    Component: J104 C4 440 V2 0003
    Revision: --020--- Serial number: 00000775996942
    Coding: 0000345
    Shop #: WSC 05311 000 00000
    VCID: 1F4D5A32CEA6FD1
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 GG HW: 1K0 820 047 GG
    Component: Climatic PQ35 141 0909
    Revision: 00141027 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 6FED6AF27E862D1
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000007491286
    Coding: 10848F0340041A00470000000F000000000859435C00010000 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 71E96C8A68B23B1
    Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
    Component: Wischer 180707 003 0205
    Coding: 00046997
    Shop #: WSC 05124
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 108358 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 12:58:00
    Freeze Frame:
    OFF
    Voltage: 12.40 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
    Component: 17 AIRBAG VW8R 032 2522
    Revision: 13032000 Serial number: 003B2PHE27FA
    Coding: 0012599
    VCID: 3169AC8AA8327B1
    Part No: 3C0 959 339 B
    Component: BF-Gewichtsens. 007 0003
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
    Component: Lenksäulenmodul 006 0010
    Revision: 00006000 Serial number: 3C5953507BK
    Coding: 0000013
    VCID: 3561989A5C5A571
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
    Component: KOMBIINSTRUMENT VD1 1216
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007205
    VCID: 285F41EE9BE83A9
    1 Fault Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 108358 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 13:19:57
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 E HW: 3C0 907 951
    Component: J533__Gateway H10 0080
    Revision: H10 Serial number: 1200P078280AB2
    Coding: F9807F070012021002
    VCID: 234556C2E2CED91
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 108358 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 12:58:12
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 108358 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 13:19:57
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 3C0 919 965 HW: 3C0 919 965
    Component: Kompass 005 0003
    Revision: 00005000 Serial number: 1166279TRJCC06
    VCID: EDD1F0FAF48A5F1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 108358 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 12:58:11
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
    Component: IMMO 051 0383
    Revision: 00051000 Serial number: VWZCZ000000000
    Shop #: WSC 02112 444 84152
    VCID: 73E5668212AE091
    Part No: 3C0 905 861 J
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1131
    Revision: 32008001 Serial number: 00000558978824
    Coding: 0001205
    VCID: 3B758EA27A7E811
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.134 H08 1901
    Shop #: WSC 02069 000 90108
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 RDK 051 0221
    Coding: 13910F8001862E521004141FF08A0F0E085C00
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 108358 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 12:58:13
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1131
    Revision: 32008001 Serial number: 00000537678827
    Coding: 0001204
    VCID: 3C778DBE7F70869
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
    Component: J540 EPB3 VW-09393 0009
    Revision: 008 Serial number: 00000000147454
    Coding: 0000057
    VCID: 295944EA80E2031
    3 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 1
    Fault Frequency: 5
    Reset counter: 123
    Mileage: 108360 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 17:18:17
    Freeze Frame:
    Voltage: 13.60 V
    Count: 10
    Speed: 0.0 km/h
    Hex Value: 0x12F0
    Hex Value: 0x0001
    Hex Value: 0x0101
    16366 - Control Module - Internal Malfunction; CPU 2
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 116
    Mileage: 108628 km
    Time Indication: 0
    Date: 2012.07.31
    Time: 13:20:39
    Freeze Frame:
    Voltage: 12.10 V
    Count: 41
    Speed: 0.0 km/h
    Hex Value: 0x12F0
    Hex Value: 0x0001
    Hex Value: 0x1010
    16352 - Control Module - Electrical Error
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 5
    Reset counter: 123
    Mileage: 108360 km
    Time Indication: 0
    Date: 2012.07.27
    Time: 17:18:17
    Freeze Frame:
    Voltage: 13.50 V
    Count: 42
    Speed: 0.0 km/h
    Hex Value: 0x12E0
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 56: Radio Labels: 1K0-035-161.lbl
    Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
    Component: Radio DE2 014 0019
    Revision: 00014000 Serial number: VWZ4Z7G6286027
    Coding: 0040402
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
    Component: J388 TUER-SG HL 1118
    Revision: 12006001 Serial number: 00000002205812
    Coding: 0001168
    VCID: 3E7387B6696C949
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0450
    Coding: 0100101
    Shop #: WSC 05311 000 08193
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
    Component: J389 TUER-SG HR 1118
    Revision: 12006001 Serial number: 00000002205099
    Coding: 0001168
    VCID: 3F8DFAB26E669D1
    End ---------------------------------------------------------------------
  2. 08-05-2012 08:49 PM #2
    I notice that most of the faults occur at 108,358 km, which translates to 592 km ago or 367 miles ago. That was probably right around the time I took the car in for 4 different recalls, 3 engine and the immobilizer. Could that have anything to do with this? I have not gotten any dash warning lights and the car is behaving normally other than the occasional parking brake dash switch fault.
    The following are the recalls that were done:
    17D2 Breather Valve
    24W2 Intake replacement
    24W3 Pressure sensor fault
    Plus the immobilizer recall- have to find the paperwork before I can get that info here.
  3. 08-06-2012 12:29 AM #3
    I think I'll reset the DTCs after I get the parking brake switch replaced and see what pops up again. The DTCs related to the steering concern me.
    Sent from my DROID RAZR using Tapatalk 2
  4. 08-09-2012 09:44 AM #4
    Anyone? Are these faults a problem? I just erased all the DTCs so we will see if they come back. They don't seem to have repeated (scanned again and the date of each DTC was the same).
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    08-09-2012 10:21 AM #5
    They're all intermittent. If they clear and don't return, no worries.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  6. 08-09-2012 07:03 PM #6
    Thanks. I'll check it again in a few weeks and see what's up.
