Results 1 to 6 of 6
Thread: Problem with 12 Volt power plug
    Jul 13th, 2007
    Bucks County, PA
    2008 Passat, 2.0Tsi, 2012 Passat SE w/roof, 2006 BMW Z4, 1997 Toyota Landcruiser
    08-05-2012 10:34 PM #1
    After over 4 years and 52K miles, finally have a non related routine service issue and would appreciate some help. Power from both 12V power plugs (front and in the rear of the console) suddenly stopped working today. I've never used the rear plug and have used the front plug with a two prong splitter for my radar detector and gps. Just stopped getting power earlier today. I'm guessing a fuse blew? If so, anyone else have this problem and can advise what fuse to look for in the box? If not a fuse, anything else to consider before taking car in? Appreciate any suggestions.
    Current: 2008 Passat (Candy White) 2.0tsi / APR Stage 1 / "ABT" style front lip / SS Tips / Drivers Gear Springs / Passat Door Sills / R-line Dead Pedal / 3M Wood Grain Dash Accents / ClearBra / 17" Monte Carlos with ContiExtreme DWS.....Current: 2012 Passat SE (Candy White).....Former: 2009 Jetta / 2003 Passat / 2003 Jetta / 2000 Jetta / 1968 Type 3 Beetle / 1965 Type 2 Microbus / 1956 Type 1 highly modified (Oval Window)
    Jul 13th, 2007
    Bucks County, PA
    08-06-2012 04:42 PM #2
    Just checking......anyone?
  3. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    08-06-2012 05:42 PM #3
    The fusebox layouts are notorious for be incorrect. Your best best is get a simple test light for a couple bucks (if you don't already have one) and hunt down the blown fuse.
    If you want to trying and use the fuse layout here it is. B6 Fuse layout
    2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
  4. Member Derek's Avatar
    Feb 18th, 1999
    Tualatin, OR
    06 Passat V6 4Motion Sport
    08-06-2012 08:09 PM #4
    Same thing happened to me. It turned out to be a fuse, but just like B6 Passat said it was not where the manual said it should be. The blown fuse was even in the left side dash fuse box instead of the right side!
    2006 Passat V6 4Motion
    United Gray, Black Leather, Sport Pkg 2, Dynaudio-600W, paddle shifters, 18" Matte Black Samarkands, Hi Def rear lip, K&N, Deleted center muffler - Magnaflow rears, 4" Magnaflow tips, H&R Sport Springs, Plasti-dipped grille & trunk panel, LEDs. Stoptech cross-drilled/slotted rotors <-Coming soon
    Jul 13th, 2007
    Bucks County, PA
    08-07-2012 03:47 PM #5
    I solved the problem and want to pass along a couple things to note in case anyone else has the same issue. There are three fuse boxes...engine, and left and right side of dashboard. Open both front doors to expose the fuse box panels and pry open with screwdriver. The 12V power outlet is a 20amp (yellow) fuse. Do not pay attention to the owners manual....fuse locations are totally incorrect. Like Derek said, the correct 20amp fuse should be located in the drivers side box and is the lowest yellow 20amp fuse in the box.....sits by itself. Yours might be a different location but just pull out and check and easy to replace. A two-pack at Pep Boys sells for $3.79. Takes less than 10 minutes and beats a $50-60 dealer charge.
  6. Member
    Jul 8th, 2012
    Atlanta, GA
    2009 Volkswagen Passat Wagon 2.0T, 2012 Hyundai Sonata 2.0T SE
    10-09-2012 09:33 AM #6
    Quick bump for this thread as I have a question. Both of my plugs also stopped working. I bought my 2009 wagon CPO with the extended warranty. Is this something the dealer could take care of with no charge?
    The one caveat is that I did the Euro cupholder mod. I'm concerned that they'll see this and declare any power plug problems will not be covered since I had to unclip these harnesses when I took apart the console.
    2009 B6 Passat Wagon - Reflex Silver - Euro stuff: front indicators, tail lamps, cupholder and first aid kit - eBay climate knobs - donut tails mod - burl wood dash wrap - Touareg-style rear footwell lights
