Where are you located? Any rust?
#1
ITR- 1.8L 16v Cyl. Head w/ 276° Schricks
TT Adj. Cam Sprocket[Used]
MJM Timing Belt w/Tensioner Kit
TAP Belts (3)
MJM Head Gasket-Metal
VW Waterpump Studs
TAP Oil Pan Windage tray w/ Gasket
BFI Prothane Rear Motor Mount Insert
ITR Factory Rear Motor Mount Bracket (old style)[Used]
MJM Head Stud Kit
TAP Injector Insulator insert/caps
MJM Rod Bearing Set, Standard
TAP Vacuum line
AZ Vacuum Caps
MJM Fuel Injector Seal Kit
ITR 50mm Intake Manifold (Upper & Lower)[Used]
ITR 50mm Intake Manifold Gasket
TAP Mahle Oil Filters (2)
ITR Timing Belt Cover (Upper)[Used]
ITR Vibradynamics Front Motor Mount[Used]
BFI Rear Motor Mount (Non-Hydralic)
ITR Crankcase Breather Hose[Used]
ECS Crank Position Sensor
WM Mobil HM 5Q
ECS Magnetic Oil Plug
Transmission
TAP Shift linkage Bushing Kit
BFI Shift Selector with ball
TAP Sachs Clutch Kit
ITR Lightened Fly Wheel[Used]
TAP Transmission Gasket
TAP Transmission Seal Kit
VW Speedometer Seal
ITR 9A Transmission (8v Close Ratio)[Used]
ITR MK3 Weighted Shift linkage[Used]
ITR Shift linkages
ECS Magnetic Transmision
TAP Transmission Mount
Suspention & Steering
Bilstein PSS
Strut tower bearings - Corrado
MJM Control Arm Bushings (4)
MJM Strut Mount & Bearing Kit
ITR PowerFlex Rear Trailing Arm Bushings
AZ Rear Wheel Bearings (1)
AT Poly Powersteering Bushing
TAP Lower Ball Joints
RPW Swaybar Hardware (Rodends)
ITR CV Joint Repair Kit
ITR Powersteering Pully[Used]
AZ Lucas Oil Products: Power Steering Fluid & Coolant
AZ Coolant
ITR Lower Ball Joint Nutplate[Used]
ITR Factory Rear Shock hats with stock bushings[Used]
Fuel System
ITR Fuel Filter
Parts4VW: Main Pump Fuel Line
Fuel - 12 gallons
VW Fuel Pump O-ring
TAP Fuel Pump (main)
TAP Fuel Pump (Pre-pump) Vemo
TAP Fuel Pump (Pre-pump) VDO
AZ Fuel Line- Low PSI
CAP Fuel Line- High PSI
Ebay (4) 12mm Banjo Fittings (Fuel)
Ebay Washers (12) Copper
Samba Passat Fuel Housing [used]
ACE S/S Fuel Clamps (11)
ITR Cold Start Fuel Line[Used]
Electrical System
VW Dash lightbulbs (3)
ITR Turnsignal Switch
ITR Electrical Clips, Fuses, Wire, etc.
AZ Sylvania 1157 turnsignal bulbs
ITR VR6 Battery Cables[Used]
Brakes
Corrado 280 mm brake kit
MJM Stainless Steel Brakelines-Front
AZ Rear Brake Pads
AZ Brake Fluid (Synthetic Dot 4)
ITR Checkvalve[Used]
ITR Brake Booster Vacuum line[Used]
Legend
ITR - Island Tech Racing
MJM- MJM Autohaus
TAP- Triangle Auto Parts
VW- VW Dealer
BFI- Black Forrest Industries
AZ- Autozone
ECS- ECS Tuning
WM- Walmart
RPW- Racers Parts Wholesale
CAP- Central Auto Parts
ACE- Ace Hardware
New Falken 615 205/40-16 tires,
Techtonics Header
Chip - Techtonics
Schrick Cams 276
K&N
Euro 50 mm intake
ARP Head studs
Sachs Sport Clutch
Lightened Fly-wheel
Will not go any lower than 5k, and will not trade. The engine itself only has about 600 miles on it. Call or Text 727-239-2362
http://a7.sphotos.ak.fbcdn.net/hphot...48684162_o.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...80594910_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...41536591_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...27136865_n.jpg
http://a8.sphotos.ak.fbcdn.net/hphot...06944621_o.jpg
