Results 1 to 2 of 2
Thread: Misaligned Top: Guidance needed
    Jun 11th, 2010
    New Freedom, PA
    86 white cabriolet, 03 Red Jetta 1.8t
    08-06-2012 07:55 AM #1
    Working on my Cabby project and cant seem to get the top lined up. It is skewed. I'm I missing an adjustment or is my frame bent?
    Thanks of the help.
    Kind of hard to see with the seal in place, but the drivers side seems good and the pass. side of the top is off.
    Untitled
    Untitled
  2. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    08-06-2012 04:54 PM #2
    Quote Originally Posted by Andy Mac View Post
    Thanks of the help.
    Untitled
    Untitled
    Lower the rear window unlatch the top, then re-latch it, fixed? Window out of adjustment on the rail interferes with the top frame.
    Remove the clip holding the strut for the top at the bottom pivot, and remove the strut from the pivot. unlatch the top and re-latch, fixed? top strut bad.
    You can get to it from the trunk.
    Still not fixed?
    Take the rear rear back out.
    Remove the rear 1/4 panel cards.
    Remove the top latching knobs.
    Remove the covers over the frame.
    You will see there are 4 bolts holding the top frame to the chassis.
    Open and close the top and watch them do they move? if so you need to reposition them and tighten the bolts.
    If not you can try this, as I have done it once on a top of mine for the same issue.
    Loosen all the bolts, I said loosen.
    Take the rear bolt loose and bend that finger out. That is a stop for the frame and can get bent.
    by taking it loose and bending that finger you change the geometry of the mount slightly and if it looks totally different from one side to the other that is probably your issue.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
