Results 1 to 9 of 9
Thread: Best thing to do for Cedar Deck
  1. Member SteveMKIIDub's Avatar
    Nov 6th, 2003
    2013 Toyota Corolla, 2010 Toyota Corolla.
    08-06-2012 09:22 AM #1
    Ok, so we put on a Cedar deck that is around 700 sq ft. We haven't stained it or done anything with it.
    Now I'm not sure what to do. I'm worried if we do stain it that in 2 years the nightmare will return and I'll be doing it all over again.
    What else can you do? I'm assuming nothing will just cause the deck to grey overtime, no?
    Any help appreciated..
    "I don’t want the company to be driven by numbers. I want it to be driven by making better cars and contributing to society. That will turn into profit, which we can use to develop better cars. That should be the cycle, and that will, as a result, build a company with a strong foundation."
    -Akio Toyoda
  2. Member barry2952's Avatar
    Jun 13th, 2007
    Farmington Hills, MI
    08-06-2012 09:57 AM #2
    Why did you spend the money on cedar if you're just going to treat it? It's naturally weather and bug resistant.
    Let it gray and power-wash it every couple of years.
    Garmin Is My Pilot.
  3. Member SteveMKIIDub's Avatar
    Nov 6th, 2003
    08-06-2012 12:39 PM #3
    Assumed you had to treat it (I knew it was "rot" resistant naturally).
    What do you need to put on before a gentle pressure wash?
    -Akio Toyoda
  4. Member barry2952's Avatar
    Jun 13th, 2007
    08-06-2012 12:44 PM #4
    It has natural oils that make it water resistant. You could seal it. I don't think that will do any harm, but don't expect that to keep it from turning gray.
    You're probably better off not using a power-washer on cedar as it's very, very, soft and high-pressure water could easily remove material. They make deck wash that you brush on and hose off. That would be better.
    Garmin Is My Pilot.
  5. Member SteveMKIIDub's Avatar
    Nov 6th, 2003
    08-06-2012 12:53 PM #5
    So in a couple of years simply brush on special deck wash, hose off and it should look like new again?
    Seems to good to be true..
    -Akio Toyoda
  6. Member
    Mar 24th, 2001
    Beaverton, OR
    2 Miatas, 2 Saabs, & a G35 sedan
    08-06-2012 03:36 PM #6
    Quote Originally Posted by SteveMKIIDub View Post
    Sort of. Any wood in the sun is going to fade and wear, regardless of deck stain or not. Cedar just happens to be a little more resilient depending on your area. NO deck stain is going to last more than a few seasons without needing reapplication or cleaning.
    Also, pressure washing is OK, but you need to make sure you use the low PSI nozzles or you'll remove the soft wood on top and it will leave ridges (ask me how I know).
  7. Member SteveMKIIDub's Avatar
    Nov 6th, 2003
    08-06-2012 06:05 PM #7
    So by doing nothing, but every year or so just cleaning and washing off (no sanding) it should "return" back to normal?
    I only splurged for cedar because it was $0.86 / LF. Didn't seem so bad!
    -Akio Toyoda
  8. Member drhavoc's Avatar
    Mar 1st, 2001
    Calgary
    08-09-2012 05:22 PM #8
    I used this stuff on my Cedar deck it's awesome http://www.penofin.com/products_rl.shtml
    it works like a charm you can simply spray it on its all natural and it keeps the Cedar from turning grey.
  9. Senior Member spockcat's Avatar
    Jun 4th, 2003
    07 Z4MC, 11 328i Touring
    08-09-2012 07:49 PM #9
    Quote Originally Posted by drhavoc View Post
    What is that, knotty pine? I'd be afraid I was stepping on something or going to trip over something.
