Results 1 to 6 of 6
Thread: Oil pan or plug stripped??
  1. Junior Member N8racer's Avatar
    Apr 12th, 2011
    Keller, TX
    2011 Jetta SE, 2010 Passat
    08-06-2012 09:47 AM #1
    I think I know the answer to my question but I just changed the oil on my wife's 2010 TSI 2.0T and over tightened the drain bolt. Now it gets loose then tighter but not really tight. Pan or the bolt stripped?? I put RTV gasket maker around it so it won't dump all the oil out only bout size of a quarter overnight. I figure it's the pan. Is it a steel or Aluminum pan? So any cheap fix suggestions?? I'm kicking myself for doing this!! My wife less than pleased to say the least!!!!
    2011 Jetta SE Tornado Red, 2010 Passat Reflex Silver
    Mar 10th, 2009
    2006 Passat 2.0t 6mt
    08-06-2012 09:59 AM #2
    Quote Originally Posted by N8racer View Post
    Your pan is steel and aluminum. The part that would have stripped is steel.
    http://www.vwpartsdepartment.com/par...gramCallOut=31
    Need lower pan of part 31 and need part 32/gasket sealant for the pan. It can be fixed for under $200.
    It can be done cheaper if you want to use a Time-Sert. This is an approved VW/Audi fix. Catch is its typically an Aluminum pan fix so it would be a lot hard to do it this way with a steel pan.
    http://www.timesert.com/html/drainplug.html
    http://www.amazon.com/TIME-SERT-Metr.../dp/B003SER3XW
    Edit: Added more information for addition fix for you.
  3. Junior Member N8racer's Avatar
    Apr 12th, 2011
    Keller, TX
    08-06-2012 03:46 PM #3
    Well I guess I'll just get a new pan. It looks like it will just drop out but it can't be that simple can it? Is there some sort of hidden gotcha that I'll encounter once I get under there? Or is it a simple drop and replace??
  4. Junior Member Made in America's Avatar
    Apr 10th, 2011
    2010 Passat Wagon 2.0T
    11-21-2012 08:22 PM #4
    http://www.ecstuning.com/Volkswagen-...979/ES2574829/
    ECS has the pan for $51.
    They also have the gasket for $28
    I've been searching every where to see how difficult it would be to remove the pan. If it's a straight unscrew and drop I'm all over this. If I have to drop the sub-frame it's going to the mechanic.
    Has anyone dropped the oil pan on 2.0T?
  5. Member pq46er's Avatar
    Aug 22nd, 2007
    Ottawa
    2007 Passat wagen
    11-22-2012 12:45 PM #5
    No the quickest & cheapest fix would be to get one of those tap and die kits specifically made for oil drain plug repairs.(Google it) Buy a torque wrench for future use. Then by a bottle of Red wine for “she who must be appeased”
  6. 11-22-2012 01:42 PM #6
    If the threads aren't too bad a M14 x 1.5mm tap should clean it up, but you may still need to drop the pan to remove the metal filings. You would also need a good handle for the tap not hose crappy ones that come in the kits. If the pan is easy to drop then buy the pan because a good tap in that size and a good handle sourced locally will run you close to or more than $50 unless you use ebay.
