sounds like the valve lifters/pucks are getting worn thru by the camshaft. If you take your valve cover off you can look where the camshaft lobed meets the valve lifter, I bet you they well be worn or look bowed inward. If so look at the cam for wear. YOu should replace the cam and lifters. Good luck.
